The area where the glob of RTV is located helps to channel water to the back edge where it drains down behind the tail lights and rear fascia. My original seal had a glob of sealant on each corner where the seal fits over the sheet metal flange. Normally, the lip of the seal overlaps that gap as yours does on the left side. I didn't glue my replacement NOS gasket in place and sometimes when working in the engine bay, it will pull back from the corners as yours has on the right side. I just tuck it back into the corners before closing the deck lid.
I deliberately didn't glue it so that I could slip the gasket off its front body flange when I'm up in the trunk doing tune-ups etc. I rest my knees against where the gasket would be. That's how I damaged my original gasket which had spots of adhesive across its length.
I find that being able to pull the gasket back as you have, allows me to remove leaves, maple seeds, pine needles, and such from that area.
[This message has been edited by fierofool (edited 03-30-2023).]
