  Fiero WIper Arm Dorman Comparison
Fiero WIper Arm Dorman Comparison by ArthurPeale
Started on: 03-05-2023 06:46 PM
Replies: 2 (418 views)
Last post by: jmbishop on 03-06-2023 11:21 PM
ArthurPeale
Report this Post03-05-2023 06:46 PM Click Here to See the Profile for ArthurPealeSend a Private Message to ArthurPealeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dan Edgley gave some measurements on his wiper arm splines, and I discovered that the splines on my Fiero were smaller than the ones he reported, by nearly 100th of an inch.
I attempted to use the same Dorman Products wiper arms he reported in a previous post a few weeks back to to avail.
I'd like to start a database of the sizes of the wiper arm splines, and cross reference that data by year and model of Fiero.
Mine is a 1986 SE V6. I know his is also a 1986.
https://youtu.be/SLJpCQpeKyI
Report this Post03-05-2023 10:24 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
I only cover some issues using new arms in other threads. More info...
1. GM and other Arm pivot ends have a lot of tension when mounted that should Not care about such small differences.
Just Try lifting the arm at same distance from spring pivot as the ball end.
Is Why Lisle 65750 Windshield Wiper Arm Remover is very handy even on Fiero because nail or drill in hole to removal can have problems.
2. OE Fiero and others arm sockets have "notches" to hold the ball that itself isn't smooth and can see as wiper end has to rotate a bit down or up as you mound it on the ball.
In Fact Often can tell when some fool removes the arms for whatever reason because wiper hits the hood and trim or is Parked too high because fool uses 1st try to mount them. That's skipping OE left and right arms are made different even if same length on most models and many put the arms on the wrong side.
Result of 1+2 = issue is 3rd party arms may have no or very small notches and can't hold the ball properly.
3. That's completely ignoring rust etc.
Even OE Arms may not fit after removal because arm socket, ball or both have "rust" and changes size of either. Seen it happen a lot like in states w/ high road salt use. Even with arms w/ tapers and nuts to mount them, once removed stirs up the "rust" and taper won't hold.
Many times can "fix" them, often temporary, by shimming them w/ whatever thin metal at hand.
If wiper are on w/ key off after driving then Key On in Winter... can have a lot of problems then just F'd arms as wipers get frozen or jammed by snow.
4. Sorry but Diff of 100th of an inch and More is often cause by the people that measure whatever and more people involved with this "project" means Database is worthless.
Just 3 of many problems:
Most don't buy Starrett and other real Pro Tools and that alone will cause errors.
Even if they buy those High $ tools, most never learn how to use them causing errors.
Exactly where you measure a part can also cause errors.
And that's only measuring the pivot head.
Dorman arms can have different dimension(s) from batch to batch and you can't even say what batch you get/got because may sit in some part store warehouse for years. Dorman like others can have wider tolerance just to make 1 batch to keep Cost to make the parts lower.
jmbishop
Total ratings: 169
Report this Post03-06-2023 11:21 PM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's a little variance, but the dorman arms don't fit because they are the wrong arm. As I posted in another post, if you want some blemished arms, I can sell some, but I'm not getting new arms until I find a new manufacturer.
