  What is the specific name for this and where can i get a new one?
What is the specific name for this and where can i get a new one? by FuzzyDice
Started on: 03-02-2023 06:16 PM
Replies: 3 (323 views)
Last post by: 82-T/A [At Work] on 03-02-2023 08:18 PM
FuzzyDice
Report this Post03-02-2023 06:16 PM Click Here to See the Profile for FuzzyDiceSend a Private Message to FuzzyDiceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spadesluck
Report this Post03-02-2023 06:28 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I assume you are referring to the metal piece aka Dog Bone. Try Rodney Dickman or The Fiero Store to find what you need. The bushing is not all that hard to replace..
sleek fiero
Report this Post03-02-2023 06:30 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
hi I think your talking about the dogbone which steadies the top of the engine . I do believe The Fiero Store carries the replacement bushings and or comlete dogbones. sleek fiero
Report this Post03-02-2023 08:18 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by FuzzyDice:
The only thing I'll say, is that if you decide to replace the dog bone with one that uses polyurethane, it will definitely have a much tighter feel to it, and you will feel quite a bit more vibration in the engine compartment. That said, the polyurethane really helps prevent that engine "rocking" feel. Even with new rubber bushings, it still will rock band and forth under heavy throttle and shifts. You really don't want that. I went with the poly bushings myself. I remember it being annoying enough that I tried to do something about it, and I installed rubber isolating washers in the seat tracks where it mounts to the floor frame, above and below the track. It actually worked!
