  1988 Fiero 2.5L 5 Speed TBI Injector not firing/spraying during crank
1988 Fiero 2.5L 5 Speed TBI Injector not firing/spraying during crank by WHIZKID355
Started on: 02-11-2023 05:53 PM
Replies: 3 (614 views)
Last post by: theogre on 02-12-2023 03:09 PM
WHIZKID355
Report this Post02-11-2023 05:53 PM Click Here to See the Profile for WHIZKID355Send a Private Message to WHIZKID355Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello everyone. So I have been working on these 2.5 duke Fiero's for years and have ran into a problem I can't seem to solve. After some testing I have determined that the ECM is not sending a signal to the TBI injector. There is 12 volts going to the red wire but after a test of the node light it is in fact dead when cranking, no signal from the blue wire. This happened all of a sudden after it started up for a split second and died. No issues or drivability issues prior to it going out. Other tests included fuel pressure, spark & oil pressure, all ok. Spraying fuel directly into the TBI and it will run. I tried another ECM I got from the wrecking yard from the same year vehicle, transmission and has the same results, no signal from the blue injector wire. Any ideas on what to explore next for troubleshooting before I send it off to someone who knows about these TBI systems? Thanks for any help you can provide.
Report this Post02-11-2023 07:51 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
ECM turn on by switching injector to ground. Find a Noid Light to test the injector signal.
ECM doesn't run fuel injection until sees good ignition but ECM can have other problems...
Clean/fix all "grounds" bolted/screwed to whatever in the engine bay.
See my Cave, Ground "Myth" notes
Any used ECM must be same type = GM 1227748
See my Cave, 87-88 DIS Duke ECM at bottom
Used GM units maybe bad too.
Cracked solder and more can make some part "dead" while rest is working.
So Old ECM can have similar failure. More so if came from Fiero that make ECM to run hot.
See my Cave, ECM Heat
WHIZKID355
Report this Post02-11-2023 10:48 PM Click Here to See the Profile for WHIZKID355Send a Private Message to WHIZKID355Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks sir. I was having issues getting to the cave but found that Firefox is the only web browser that I have that can access it. Just out of curiosity if the crank sensor went out would it cause this? I'm assuming no because it's getting spark. Also is it common for high milage ECMs to quit like this? The ones I have tried all had around 165k miles on them including the existing one in there now.
[This message has been edited by WHIZKID355 (edited 02-11-2023).]
Report this Post02-12-2023 03:09 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now Seems Doogle Chrome and likely others based on the crap now hates shorturl.com
This page isn’t working
fierocave.shorturl.com redirected you too many times.
Try clearing your cookies.
ERR_TOO_MANY_REDIRECTS
so Not my problem and cleaning cookies etc won't help.
Yes, crank sensor is fine when have spark.
25+ year old ECM can have many problems. So can Fiero Radio, Tack, and more.
Besides can "wear out" normally, Car Cabin and everything in it can heat cycle just from Sun parked outside as cabin easy hits 150+°F in "Summer" to Freezing and low in Winter.
see https://www.fiero.nl/forum/Forum2/HTML/141784.html Fiero Engine bay vs Heat.
Is worse for Fiero ECM because start hot or cold when parked and get even hotter as air is blocked so can't cool right as link above covers.
So old electronics for cars often fails.
Again, have to check/fix all grounds in the engine bay at minimum.
Take apart, clean, inspect then coat w/ silicone or permatex brake grease to prevent "rust."
Clean the engine transmission and hardware too when wire ends hit. "demmel" w/ wire wheel may help. Note wire wheel and other tips last way longer when used w/ lower speeds. Say middle speeds ~ 40-60%. Even them need eye protection and other relative PPE.
