  Rack and Pinion lubrication
Rack and Pinion lubrication by Ray 86
Started on: 11-19-2022 07:22 PM
Replies: 5 (712 views)
Last post by: Ray 86 on 11-21-2022 04:01 PM
Ray 86
Report this Post11-19-2022 07:22 PM Click Here to See the Profile for Ray 86Send a Private Message to Ray 86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am in the process of changing the shimmy damper on my 86 GT and noticed a plug on the top of the rack and pinion. Should there be a grease fitting there? If so what kind of grease should be used?
Total ratings: 466
Report this Post11-19-2022 11:11 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're probably seeing where an adjustment can be made.
Steering Rack bearing (play) adjustment. Help needed.
Ray 86
Report this Post11-20-2022 01:13 PM Click Here to See the Profile for Ray 86Send a Private Message to Ray 86Edit/Delete MessageReply w/QuoteDirect Link to This Post
As you can see in the picture the plug is located on the top surface of the rack. I is hexagon takes a 6mm socket
[img]https://images.fiero.nl/userimages/Ray%252086/IMG_20221120_125413.jpg
[This message has been edited by Ray 86 (edited 11-20-2022).]
RWDPLZ
Total ratings: 306
Report this Post11-20-2022 01:22 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post11-21-2022 09:51 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Rack is Not made to have anything done including you adding whatever grease.
Many that try added the wrong grease or other lube and cause more problems in the future. Near Future depending on grease and other issues.
Don't try to fix unless you have right tools etc. before taking apart.
Ray 86
Report this Post11-21-2022 04:01 PM Click Here to See the Profile for Ray 86Send a Private Message to Ray 86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got it!
Thanks for the input.
