Axles and other things Will Not prevent water getting inside when pressure washing.
Axle and other lip seals are not made to get hit with pressure and can even wreck them w/ pressure washer.
Trans Vent to air and O-ring on VSS may not seal either or VSS itself can have problems hit w/ pressure washer.
Remove big crap w/ scraper etc before you wash w/ anything.
Use engine cleaner in somewhat in small areas so never dries and use brushes to work the chemical.
Then rinse before chemical dries.
