The Eaton Gen V supercharger has a slightly different bolt pattern than the Gen III supercharger. You will most likely need the late 04-06 manifold to change over. The Gen V does run cooler and although the cubic inch displacement is the same it will produce more boost. On my setup with a 3.4" pulley (intercooler needed) it puts out 11 psi of boost. The engine is very fast and powerful. You slam that pedal down and the power is instantaneous.
"THE COLUSSUS" 87GT - ALL OUT 3.4L Turbocharged engine, Garrett Hybrid Turbo, MSD ign., modified TH125H
" ON THE LOOSE WITHOUT THE JUICE " [This message has been edited by Dennis LaGrua (edited 09-11-2022).]
