So I came across a spare intake and decided to try my hand at some aluminum brazing in an attempt to recreate the Dawg mod. Brazing rods melted well enough to the new aluminum, but wants nothing to do with the base intake material and wouldn't fuse at all. Anyone good at this to give me some pointers? My best guess is that I'm not getting the intake side hot enough.
I don't know anything about this but am just interested to hear what your set up is. MAP gas with the standard Home Depot torch? What type of rods are you using? Any flux?
[This message has been edited by Notorio (edited 08-17-2022).]
I would have expected those to be welded too. I would definitely clean up the surrounding area more though, theres a lot of paint right on the seam where you're brazing. I don't know if the adage is applicable to braze, but as they say "80% of a weld is surface prep"
Very likely you can't make enough heat using Propane or "MAPP" torches for large intake manifold. Worse, these torches breath normal air and contaminated the aluminum your trying to heat.
⚠️ All Current "MAPP" is Not the same like Bernzomatic MAP-Pro and often perform different then discontinued MAPP made years ago. see MAPP wiki...
Bernzomatic makes ox/mapp torches for consumer use but only have a very small tip and likely won't help here or cause more problems. Even if you buy the torch kit, finding the small oxygen "bottles" are hard in many places.
Find a welding shop to TIG or MIG weld the parts.
A buddy of mine welded my manifold mod- did great job and I tested it going up-hill on a freeway in fourth...My 85 V6 (3.4 f-body/Getrag) Fiero did 4500 un-modified, then with the modified manifold it did 4800 rpm.
[This message has been edited by cvxjet (edited 08-18-2022).]
He is not only a good welder- he took metallurgy classes so he actually knows what's going on when he is welding. Back around 2001 he spent a whole Saturday shortening my boat trailer (To fit my garage) and would not let me pay him...Later, I bought him a copy of a great book (Muscle Car Chronicle) and he wanted to pay me for it- I told him "Take it or else!"
CVXJet, is he interested in possibly doing this for other Fiero members? I can weld like it's no one's business... but only with a flux-core and anything less than 1/8th inch steel. I would feel much better having you're buddy do it for me. Would you be willing to ask him?
I have to tell you- probably not; He is 78 years old and has Diabetes, so he lucky to just be alive.
He welded my intake, and also my custom "B" pillars....I want to do a hex-grill covering for the tail lights with slot trailer LED lights behind in the blacked out cavity....But A) It is hard to get everything designed/aligned, etc...and B) I am not sure he can even do that bit of welding anymore...
[This message has been edited by cvxjet (edited 02-21-2023).]
That looks pretty sweet CVX! I like the way the back came out.
I'm hesitant to modify my existing manifold since it's an 87-88 manifold (original) with the drilled FIERO words, rather than the 85-86 with the sticker. I may have a spare, but the idea of cutting into it just seems crazy! I've welded many times before with a mig welder, and I'm pretty comfortable with it, but never with aluminum. I think I'll just have to do some research. I don't have my car to look at, but is there any issue with clearance with the bump out under the neck? I can't remember if it gets in the way of a harness, the fuel rail, or anything else?
Get a MAPP gas torch from Home Depot, way hotter than propane.
Clean up your paint better in the area you want to bond. Clean it really well, and use the torch to burn off any impurities in the cast Al.
And chuck that intake in the oven prior to brazing, it will make all the difference. Very hard to get the brazing area up to temp otherwise. The Al brazing rod will work just fine.
You can always bring it somewhere and pay them to Tig it if you have no luck, but I bet it is just too cold.
That taillight mod is just a mock-up......I have not done it yet...Really difficult to make a frame that fits and secures...Then I have to bend the hex-grill to fit that frame- for welding.
The intake manifold; I grabbed an extra manifold (87 GT) from the junkyard.....then bought a piece of aluminum tubing- cut it in half, and then spent over a year slowly carving the manifold and the half-round to fit together. It fit absolutely perfectly (Except around the EGR fitting (On the inside)....After my buddy welded it, I used a rotary file on an extension to grind a few spots smoother inside.
What about a little side business where you sell the templates to us in the Mall? One for where to cut the manifold, another for where to cut the pipe. Include recommendations for surface prep. then we can take the pieces to a local shop to to the welding. I'm guessing it would just be an hour of shop time. Your thoughts?
You know....A pattern of the shape of the cut-out on the manifold would have been very schmart.....But I only use my head for a "Hat-rack"....
Here is the pattern to use for the tubing- just wrap it around a piece of aluminum tubing, mark and cut; Some of the edge is cut vertical, and some is horizontal.
To "french" it into the manifold, you'd have to cut slowly- leave some metal beyond where you >>think<< you should cut, and then grind it to actually fit. I used drills, a Dremel (Both grinding and cutting) and even some hand-filing.
Many thanks! I had forgotten about your original thread (that I had posted in, no less.) So, which one of you amazing fabricators out there can do the public service of creating the matching manifold cutting pattern?
