  Replacing rear brake rotors
Replacing rear brake rotors by Cliff Pennock
Started on: 08-02-2022 01:26 PM
Replies: 7 (761 views)
Last post by: stevep914 on 08-04-2022 04:45 PM
Cliff Pennock
Administrator
Total ratings: 699
Report this Post08-02-2022 01:26 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Two years ago, I replaced my front rotors (and bearings and pads) and that was actually pretty easy to do. This year I want to replace the rear rotors and I can remember it was even an easier job than replacing the front rotors. I had found either a YouTube video or a posting here on PFF describing how to do that. Problem is, I can't find neither. Yes, I've used the search.😁
So what are the steps for replacing the rear rotors? I'm going to replace the pads as well, and know how to do that. Just don't know how to replace the rotors...
css9450
Total ratings: 87
Report this Post08-02-2022 01:49 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
You pretty much just unbolt the calipers, hang them with a hook or a wire so they don't dangle by the hose, and remove and replace the rotors. That's about it.
Be sure to clean off any loose rust on the face of the hub, so the rotor seats nice and flush. I also apply some antisieze there too. Also, clean the oily coating on the rotors off first with brake-clean spray.
The rear calipers require more work than the fronts because they also contain the parking brake mechanism.... Probably drserves it's own thread.
[This message has been edited by css9450 (edited 08-02-2022).]
Fiero_Adam
Report this Post08-02-2022 07:18 PM Click Here to See the Profile for Fiero_AdamSend a Private Message to Fiero_AdamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, replacing the rotors on the back is easy because they just fit over the wheel bearing hub, unlike the front with the hub as part of the rotor. The harder part is messing with the rear calipers.
Here's a thread with some good info, though you may have found this already.
https://www.fiero.nl/forum/...110502-2-102452.html
Report this Post08-02-2022 08:55 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need a C-clamp to retract the pistons.
See my Cave, Clamp Method notes
before unbolt the calipers...
Release small end of P-brake cable.
Remove spring.
Remove nut and arm. (If needed put nut back on a few threads while working on other parts.)
Follow cave directions after pulling the caliper.
If caliper is "stuck" on rotor's edge... Clamp the whole thing or pry/press as shown in cave.
You clamp in center of outer pad. Pad Clips will move and push back the piston enough to clear rotor rust.
You Do Not need to Force a piston in. Force = Bad. Piston F'd or just a crap clamp.
after done, if piston(s) won't self adjust... their bad. Any manual adjust including cave is only a temp "fix" at best.
kendell
Report this Post08-03-2022 11:19 PM Click Here to See the Profile for kendellSend a Private Message to kendellEdit/Delete MessageReply w/QuoteDirect Link to This Post
Remove spring.
Sounds like much easier with the use of c-clamp
RWDPLZ
Total ratings: 306
Report this Post08-04-2022 12:11 AM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Git gud, scrub
Cliff Pennock
Administrator
Total ratings: 699
Report this Post08-04-2022 11:14 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
This morning I decided to just go ahead and do it and go from memory. In total it took me 6.5 hours for both sides. Pretty decent I would think. 😁
I did find a few problems. On the driver's side, the clip that holds the inner brake pad was missing. And i didn't have a spare so installed the brake pad without the clip - making sure it was snug against the brake cylinder when I installed the caliper. Also, there was a tiny tear in the piston seal. I do have a complete rebuild set, but rebuilding the rear caliper is something for another day/year/decade. What I did is actually glued it together with a tiny bit of super glue. Enough to make sure no dirt can get in.
The sliders of the same brake were seizing bad. I was already planning on cleaning them up and re-lubricating them, but getting them out wasn't easy. I used a flat end screwdriver and tried to hammer it out but that actually caused the bolt to get out of the slider (and destroying the bolt). I eventually got the slider out from the other side (using a socket wrench that fots the hole, and a C Clamp). Fortunately, I had two spare sliders so I threw the old ones out and used the replacements.
The last time I had the rear brake pads replaced, I had it done by a garage. And I noticed they replaced the locking nut (on the actuator screw) with a "normal" nut. Apparently that didn't really cause a problem these past years, but I know these locking nuts are "special" in some kind of way...
I used a iron-saw to change the hexagon levers into octagon levers to make my live easier installing them.
I did a test drive and my Fiero actually brakes better now. Although I can hear the pads rubbing against the rotors (can't remember the english word for that, but you know what I mean. "stick?").
stevep914
Report this Post08-04-2022 04:45 PM Click Here to See the Profile for stevep914Send a Private Message to stevep914Edit/Delete MessageReply w/QuoteDirect Link to This Post
I rebuilt my rears a couple of years ago; Autozone here in Mexico actually had the kits! Between posts here, and my Haynes manual, it was not a difficult job; just time consuming. As for the slider pins; not being able to get those here, I used very fine emery cloth to polish them up, and special grease to reinstall them. With our salt air affecting everything here, they are still working like a charm.
