Here is some actual data I just collected from my 4.9L Cadillac Fiero. The system was converted to R-134a. The 4.9L uses basically the same compressor as a 2.8L V6. It is a clutch cycling type of control. Compressor clutch engages when the low side pressure climbs high enough. Compressor clutch disengages when the low pressure drops to a certain.
Ambient conditions - 97 'F and 24% humidity
Car in the shade idling at 600 rpm
Test Condition 1
HVAC fan on Hi
A/C control button on Normal
Compressor low side pressure - 40 psig
Compressor high side pressure - 280 psig
Vent air temperature - 57 'F
Driver's side door open
Test Condition 2
HVAC fan on Lo
Compressor low side pressure - 27 psig
Compressor high side pressure - 238 psig
Vent air temperature - 43 'F
Test Condition 3
HVAC fan on Hi
A/C control button on MAX
Compressor low side pressure - 38 psig
Compressor high side pressure - 270 psig
Vent air temperature - 55 'F
Cabin Air - 68 'F
Driver's side door closed
Test Condition 4
HVAC fan on Lo
Compressor low side pressure - 30 psig
Compressor high side pressure - 260 psig
Vent air temperature - 45 'F
Cabin air - 72 'F
Driver side door closed
I thought that when the A/C was set to max it recirculated some of the cabin air back to the evaporator and reduced the amount of outside air coming in. However it did not seem to make much difference in the vent temperature if the A/C was on
NORMAL or MAX.
The compressor was maxed out for all four test conditions. It did not cycle on and off. At normal cruising rpm the compressor will have about 3X the capacity than it has at idle and so it should cycle. The vent temperature will vary depending on where the low side pressure is in the control range. At the high end of the range, 55 'F vent temperature would not be unusual. I didn't take it for a drive but the A/C in this car has no problem keeping the cabin comfortable even with 105 'F ambient.
As you can see the vent temperature will change with the HVAC fan speed. This is normal. But the system cools the car better with the fan on Hi with a 55 'F vent than it does with the fan on Lo with a 45 'F vent.
Even with only 24% relative humidity the accumulator and the lines in and out were condensing water out if the air. The boiling point of freon is 30-45 'F at normal low side pressures. If the aluminum line from the evaporator to the accumulator is not cold it is a sign of restricted freon flow. In all likelihood this is a partially plugged screen on the orifice tube. It is a good practice to change the orifice tube whenever the system has been evacuated and has been in service for a long time - especially if there are complaints of poor cooling.
Autozone et al will lend A/C gauges for free and I'm sure they will show you how to hook them if you are not familiar with their use.
formerly known as sanderson
1984 Quad 4
1886 SE 2.8L
1988 4.9L Cadillac
1988 3800 Supercharged
[This message has been edited by sanderson231 (edited 07-25-2022).]
