The muffler on the Fiero is fine to flush, it's empty, just give it time to drain and dry.
https://www.fiero.nl/forum/...160323-2-129036.htmlFour Seasons usually has a good tech line, they should be able to tell you what oil is in it.
https://www.4s.com/en/contactFiero total oil capacity is 8oz. Should be Ester or PAG for R-134A, Mineral oil is R-12 only. Mineral oil is only used to lubricate the o-rings in an R-134A system. PAG should NOT be used to lubricate o-rings in an R-134A system, it can cause corrosion. I haven't tried Nylog Blue but I've heard good things...
