  Anyone running a Quad 4 Getrag or 3.94 FDR getting VSS Code 24?
Anyone running a Quad 4 Getrag or 3.94 FDR getting VSS Code 24? by Raydar
Started on: 06-15-2022 03:00 PM
Replies: 11 (199 views)
Last post by: sanderson231 on 06-21-2022 10:42 AM
Total ratings: 460
Report this Post06-15-2022 03:00 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
As the topic says...
I recently purchased an 88 GT with a Quad 4 Getrag. Bellhousing swapped to V6 style. (I knew this, going in.)
I keep getting a Code 24 after driving for a while. Speedo works perfectly.
I'm wondering if the Code 24 is caused by the speed vs RPM error introduced by the difference between the FDR in the stock and replacement trannies. Kind of a longshot, I suppose, but it is programmable in the ECM. It's also interesting that it doesn't set the code right away.
Am I over-thinking this?
I've read all the threads here that contain "Code 24", but have not started troubleshooting yet, other than having unplugged and reconnected my speedo connector.
Anyone else running a Quad 4 Getrag or, I suppose, an F23?
Thanks.
Quad GT
Report this Post06-15-2022 09:13 PM Click Here to See the Profile for Quad GTSend a Private Message to Quad GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a W41 in my "86 SE and no issues
Total ratings: 460
Report this Post06-16-2022 08:42 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool. Thanks.
sanderson231
Report this Post06-16-2022 11:54 AM Click Here to See the Profile for sanderson231Send a Private Message to sanderson231Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know that some Quad 4 Getrags (maybe all) use a different style VSS than the Fiero Getrags. I know that when I did my Quad 4 swap, I split the case and installed the plastic gear so that I could use the Fiero VSS. I think that the Quad 4 VSS outputs pulses instead of a sine wave. I'm not sure what kind of engine/transmission your car has but perhaps the code 24 is being set because the ECU is expecting a sine wave and it is seeing a pulse.
sanderson231
Report this Post06-16-2022 05:25 PM Click Here to See the Profile for sanderson231Send a Private Message to sanderson231Edit/Delete MessageReply w/QuoteDirect Link to This Post
sanderson231
Member since Jun 2022
Also most of the Quad 4 Getrags have the same FDR as the Fiero. Only the W41 Quad 4 Getrags got the 3.94 FDR so they are rare.
Total ratings: 460
Report this Post06-18-2022 07:57 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmm... Interesting. Conflicting stories, over the years. I'll have to measure speed vs RPM, and see. (It has a lot more "giddy up" than I remember out of a 2.8.)
The VSS looks, outwardly, like the Fiero VSS, but I haven't pulled it out. (The speedo and odo both work perfectly.)
I've got another Quad 4 Getrag that very obviously is the magnetic VSS, but the VSS looks completely different, even on the outside.
Thanks for the info. Much appreciated.
sanderson231
Report this Post06-19-2022 11:19 PM Click Here to See the Profile for sanderson231Send a Private Message to sanderson231Edit/Delete MessageReply w/QuoteDirect Link to This Post
Even with the 3.61 FDR a Quad 4 HO is much more capable and fun than a 2.8.
I have a W41 that will be going into my 84 Quad 4 in the next few months. I also have three other Quad 4 HOs in the garage. I have been contemplating stroking a 2.3L Quad 4 to 2.6L with the 2.4L Twin Cam Crank. The block will be bored to either 93 or 94 mm from 92 mm. With additional compression ratio (11.5:1) I think it could produce 230 HP.
Total ratings: 460
Report this Post06-20-2022 10:50 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
No doubt! It's better suited to the flavor of the car. Like an LQ1. (I have heard that the LQ1 was part of the inspiration for the Quad 4, but who knows...)
I did some experimenting yesterday. The scan tool is seeing MPH displayed, along with the speedo (which has always worked properly). So if there's a failure, it's intermittent, and between the speedo and the ECM. The light was NOT on.
Quad GT
Report this Post06-20-2022 03:27 PM Click Here to See the Profile for Quad GTSend a Private Message to Quad GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could you turbo or supercharge it?
sanderson231
Report this Post06-20-2022 05:25 PM Click Here to See the Profile for sanderson231Send a Private Message to sanderson231Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know there have been a few turbo Quad 4 done. The 2.6L stroker is fairly straight forward. I just don't know if I want to spend the time on a turbo project.
Quad GT
Report this Post06-20-2022 07:06 PM Click Here to See the Profile for Quad GTSend a Private Message to Quad GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
What about a simple supercharger? Is there room for one?
sanderson231
Report this Post06-21-2022 10:42 AM Click Here to See the Profile for sanderson231Send a Private Message to sanderson231Edit/Delete MessageReply w/QuoteDirect Link to This Post
GM made supercharged and turbocharged Ecotec's. That might be a better starting point. Not sure about the fitment.
