  Engine temps all over the place (Page 3)
Engine temps all over the place by Cliff Pennock
Started on: 06-14-2022 03:07 AM
Replies: 82 (1588 views)
Last post by: Cliff Pennock on 01-23-2023 02:13 PM
sanderson231
Report this Post01-22-2023 06:45 PM Click Here to See the Profile for sanderson231Send a Private Message to sanderson231Edit/Delete MessageReply w/QuoteDirect Link to This Post
double post
[This message has been edited by sanderson231 (edited 01-22-2023).]
sanderson231
Report this Post01-22-2023 07:23 PM Click Here to See the Profile for sanderson231Send a Private Message to sanderson231Edit/Delete MessageReply w/QuoteDirect Link to This Post
sanderson231
Member since Jun 2022
The leakdown tester is just two pressure gauges upstream and downstream of a restriction orifice. The leakage flow rate is proportional to the square of the pressure drop across the orifice. Of course if all you are looking for is bubbles then the flow rate is irrelevant.
You could also get an idea of the leakage flow rate by just having a quarter turn valve upstream of a single pressure gauge. Shut off the air supply with the quarter turn valve and time how long it takes the pressure to decay to a certain value.
formerly known as sanderson
1984 Quad 4
1886 SE 2.8L
1988 4.9L Cadillac
1988 3800 Supercharged
Cliff Pennock
Administrator
Total ratings: 696
Report this Post01-23-2023 02:13 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
It's been mentioned at least once before (but I don't believe you addressed it)... are you absolutely positive that neither one of the two stainless steel coolant pipes that run the length of the car has been crushed?
I haven't checked. Will do that soon.
