Do Not use "Glue" or anything else to install any seal/boot on the brakes.
Only lube outer seal and plastic "shim" for park brake screw that lives between cal body and arm. That and the sliders needs Brake Grease.
See my Cave,
Brake ServiceDust boots go on the piston before install in the caliper.
Then Outer side gets "pressed" into the cal body.
The Press uses a cup to press the boot w/o loading on the piston. Can make a "cup" out of standard plastic pipe parts then carefully press w/ standard bearing/seal drivers for front wheel bearings/seals.
Inner diam maybe a bit loose but if piston doesn't seal then will have crap water and more getting in and likely sooner then later.
Outer diam should only fit when pressed in the cal body.
First issue is RockAuto... Expect problems if you need to return parts.
Go to AZ, AdvanceAuto, etc. that often can return warranty and cores to local stores.
