  Best tire setup for 87 GT (Stock Wheels)
Best tire setup for 87 GT (Stock Wheels) by AmphotEric
Started on: 05-06-2022 02:20 PM
Replies: 25 (478 views)
Last post by: cvxjet on 05-08-2022 12:05 PM
AmphotEric
Report this Post05-06-2022 02:20 PM Click Here to See the Profile for AmphotEricSend a Private Message to AmphotEricEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 87 GT is in desperate need of new tires, and the previous owner had a square setup of 205/60/r15 (stock wheels). If I want to get the best handling out of the car, so I’m unsure if I should switch to staggered, or run squared to keep the balance. I see a lot of people running 225/60/15 rear + 215/60/15 front, and I’m wondering if that is the best combination for the best handling/ride feel?
If I try to go this setup, I can only find two tire options (atleast in Canada)- Uniroyal Tiger Paws or BF Goodrich Radial TAs. Are there any other tires in the above spec that someone could recommend? Additionally, is there a better fitting tire spec that’ll be best for performance/handling?
Skybax
Total ratings: 78
Report this Post05-06-2022 03:46 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome!
On stock GT wheels its best to run the manufacturer recommended sizes of 205/60/15 front and 215/60/15 rear.
(for a variety of reasons... Oversize = overall diameter effecting speedometer, exceeding recommended rim width, rubbing, looking silly, etc)
As far as tire brands/models go, that is going to vary depending a personal taste, purpose/use, price, etc. I personally don't like BF Radial T/A's on a Fiero because they are T-Rated and overpriced due to classic car world demand. On stock GT wheels I would recommend at least an H-Rated tire. Its also wise to use a softer compound (more grip) especially if its a weekend hobby car, because the years/age you get out of the tire is more important than the miles, so harder/higher mileage tires are a poor choice for a weekend hobby car that only sees an average of 500 to 2000 miles per year/season. In summary, best to use the stock staggard sizes with an H-Rated tire that has a softer compound (lower tread wear rating).
Its getting more difficult to find a good stock staggered set for the Fiero with those specs, here is my post last year on what I ended up with...
https://www.fiero.nl/forum/...HTML/099929.html#p12
[This message has been edited by Skybax (edited 05-06-2022).]
Total ratings: 207
Report this Post05-06-2022 04:14 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ran 215 front and 225 rear on stock 15 inch wheels for decades.
Speedo error was minimal.
If you want better handling, purchase the Fiero Store front and rear sway bar set as well, they are matched as a set to work well in reducing push and making the car more neutral.
AmphotEric
Report this Post05-06-2022 04:52 PM Click Here to See the Profile for AmphotEricSend a Private Message to AmphotEricEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Skybax:
Welcome!
I hope I'm doing this right, I'm unfamiliar with using the forum so I'm not entirely sure how to reply lol
I believe because I'd be keeping the same Aspect ratio & wheel size, the speedometer will be minimally effected (if at all). I'm my experience with other vehicles, going wider (as long as your wheels can support it) gives you better handling & grip on the road due to a greater contact surface with the road. Have you ever run this spec on your fiero? Is the difference in handling negligible?
I have many more options if I search for the spec you described, but I think I'm pretty set on going slightly larger, as the only negative I see is the lack of options + impact on my wallet.
hunter29
Report this Post05-06-2022 07:55 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
I kept stock size tires and am happy. Driving on the street you don’t get to many opportunities to push the car hard so I don’t worry about it.
Bigger wider tires is more mass and just taxes horse power and brakes.
Xenoblast
Report this Post05-06-2022 08:55 PM Click Here to See the Profile for XenoblastSend a Private Message to XenoblastEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dont use square, my previous owner did that aswell and it sometimes caused me to slip a little in the rear when it rained, scary. I run stock tire sizes with ohtsu fp0612s and couldnt be happier.
Kevin87FieroGT
Report this Post05-07-2022 09:43 AM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I’ve run 205/60-15 front and 215/60-15 rear on stock ‘87 GT wheels as well as 215/60-15 on all four corners. Though the 205/60-15 on front work ok in the parking lot, the 215/60-15 in front work much better on the twisting mountain roads. For the rear the 215/60-15 are fine and grip well.
Currently I have the 205’s on the front and soon will need tires. My plan for replacement will be 215’s on all 4 corners again. The 215/60-15 are available from a number of manufactures, just takes a little searching and possibly some compromise as to the manufacturer you might choose.
I currently have BFG T/A’s and they are ok, pricey, but ok. There are better newer style tire choices available. I’ll withhold from recommending another choice for now as I haven’t looked at the market place for the last 6-9 months, but Discount Tire and Tire Rack both had a selection at that time.
Kevin87FieroGT
Report this Post05-07-2022 09:46 AM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kevin87FieroGT
Member since Nov 2010
[QUOTE]Originally posted by Kevin87FieroGT:
I currently have BFG T/A’s and they are ok, pricey, but ok. There are better newer style tire choices available. I’ll withhold from recommending another choice for now as I haven’t looked at the market place for the last 6-9 months, but Discount Tire and Tire Rack both had a selection at that time. Buy “H” rated tires if you can find them, slightly stronger sidewall than the “T” rated.
Kevin87FieroGT
Report this Post05-07-2022 09:51 AM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kevin87FieroGT
I currently have BFG T/A’s and they are ok, pricey, but ok. There are better newer style tire choices available. I’ll withhold from recommending another choice for now as I haven’t looked at the market place for the last 6-9 months, but Discount Tire and Tire Rack both had a selection at that time. Buy “H” rated tires if you can find them, slightly stronger sidewall than the “S or T” rated standard find out there.
Total ratings: 207
Report this Post05-07-2022 09:51 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Kevin.
225/60/15 on the rear pairs very well with 215/60/15 on front.
I've run that combo for years.
Kevin87FieroGT
Report this Post05-07-2022 09:55 AM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Joe,
Thanks. Getting time to retire Bob’s T/A’s.
Skybax
Total ratings: 78
Report this Post05-07-2022 10:12 AM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
While the negative effects are minimal, you can't simply discard them.
If going from 215/60 to 225/60 in the rear it will certainly change the following...
- 1/2" taller overall diameter
- Speedo read slightly higher
- Heavier in weight
- More rotating mass
- Final drive ratio will change from 3.65 to 3.58 (more highway gear)
When you combine added weight of all 4 plus-sized tires with increased highway gear, the stock 2.8 V6 will accelerate noticeably slower.
Will it handle slightly better? Maybe, depends on the tire, but at a cost of all the above. Doesn't seem worth it to me, but some people like bigger tires.
Re-read my first post, you will have better results going with stock size H-Rated tires that have softer compound (better grip) without sacrificing performance.
PS: After thinking about it some more, I think Radial T/A and Tiger Paw in those sizes are both T-Rated, so a slighter larger/taller 225/60 T-Rated tire in the rear might handle worse than a stock 215/60 H-Rated tire (despite the slightly wider contact patch) because the T-Rated sidewall will be taller and softer, resulting in more mush-rollout, so it might be a downgrade across the board (reduced handling and reduced performance) but you would have to talk to the Watkins Glen road course experts about the handling part.
[This message has been edited by Skybax (edited 05-07-2022).]
Total ratings: 207
Report this Post05-07-2022 11:23 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ran stock sized tires for years on 15" lace wheels.
One of the best things I ever did for my 85 GT and 86 SE was to switch over to 215/225 combo.
This is after running lace wheels on both cars for quite some time.
AmphotEric
Report this Post05-07-2022 03:30 PM Click Here to See the Profile for AmphotEricSend a Private Message to AmphotEricEdit/Delete MessageReply w/QuoteDirect Link to This Post
- Heavier in weight
I actually never really considered weight or gear ratios.
I'm honestly really torn. I live in an area with lots of mountains and twisty roads, so I think handling is my main priority, especially when I consider safety.
Could I circumvent the additional weight & get the best of both worlds (more contact and softer sidewall) by going 225 + 215 by running a 50 aspect ratio vs 60? Do people do this, or is a wider sidewall better for the aesthetics of the car?
AmphotEric
Report this Post05-07-2022 03:33 PM Click Here to See the Profile for AmphotEricSend a Private Message to AmphotEricEdit/Delete MessageReply w/QuoteDirect Link to This Post
AmphotEric
Member since May 2022
Did you notice a big increase in performance/handling or a decrease in speed or Acceleration as mentioned above?
Total ratings: 207
Report this Post05-07-2022 05:43 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not a bit of performance loss that was discernable, but the handling was greatly improved.
And you want stiffer sidewalls, not softer.
'H' rated tires are the ticket.
I would stay away from 50 series tires, the Fiero likes some sidewall. And the car looks a lot better.
AmphotEric
Report this Post05-07-2022 05:52 PM Click Here to See the Profile for AmphotEricSend a Private Message to AmphotEricEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is your reasoning for the H-rated? Same as Sky's above?
What tires are you running currently?
[This message has been edited by AmphotEric (edited 05-07-2022).]
Total ratings: 207
Report this Post05-07-2022 06:44 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Experience - I've daily driven a Fiero for decades, year around. Driven them hard, have spend a lot of time in the Tennessee/North Carolina area running mountain roads. 'T' rated tires don't handle ery well as compared to 'H' rated tires. I've used different several brands over the years, the stiffer sidewalls allows crisper turn-in and more control at the limit of adhesion.
The 15" tires right now are two different brands - fronts are OHTSU FP6000 215/60/15.
Its the same tire as the Falkan 512 (OHTSU makes Falkan) which were very good handling tires but weren't available.
The rears are 225/60/15 FUZION Touring, as I needed tires and they were the only thing available in 'H' rating without waiting. They aren't bad tires, I was surprised.
Both front and rear are 'H' rated.
The car (88 Formula 4.9 V8/4T60E) has run the Dragon several times with these tires.
You won't catch me.
The biggest thing to making a Fiero handle well is seat time. I've logged over 250,000 miles in the Fieros I've owned (85 GT stock 4-speed - 86 SE V6/4 speed stock for a while, then a bunch of suspension/brake/sway bar work, now the Formula) so I know what the car is capable of.
If you're just a weekend driver, you will never find out what the car can do.
AmphotEric
Report this Post05-07-2022 06:59 PM Click Here to See the Profile for AmphotEricSend a Private Message to AmphotEricEdit/Delete MessageReply w/QuoteDirect Link to This Post
You won't catch me.
Is the reason you're running different fronts and backs because the Ohtsu's aren't available in 225? I honestly can't find any tire options in the 225/60 + 215/60 aside from Tiger Paws and Radial TAs (which I believe are S rated, but I'm Actually unsure. Do you know?).
My options have been very limited. Tire Rack, Canadian Tire, 1010 Tires, etc all have the same options, or none at all. It really seems like I'm stuck going with the Radials.
cvxjet
Report this Post05-07-2022 07:16 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just checked on Tirerack; They have the Riken Raptor HR in the original 205/60 and 215/60 sizes for a total of $380. You can have them delivered to a local shop- usually Big O. Do not go with BFG Radial TA- back in the 70s and 80s they were a great tire- but now they are for the car show guys who don't do much driving and don't care about performance.
The other good option is the General Altimax RT43....They are lighter (Which will improve performance)- but they are also more expensive by $80
AmphotEric
Report this Post05-07-2022 07:25 PM Click Here to See the Profile for AmphotEricSend a Private Message to AmphotEricEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wanna do the larger size, so the Raptor won't work. I was considering the AltiMax, however I'm pretty sure that they're all-seasons that are more catered to winter. I'm not sure if they'll be a good option- what are your thoughts?
Total ratings: 207
Report this Post05-07-2022 08:25 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I run all seasons on my cars, they work well in the wet and in colder temperatures.
In my posting I explained that I got the FUZION rears because I needed the tires that day, and could not wait for something to be ordered.
AmphotEric
Report this Post05-07-2022 08:51 PM Click Here to See the Profile for AmphotEricSend a Private Message to AmphotEricEdit/Delete MessageReply w/QuoteDirect Link to This Post
I saw, just wasn't sure if they made them in both sizes, because I've had no luck so far.
I have the ability to grab the Ohtsu fp7000s (not sure how similar they are to yours). Based on what you know & your experience with running all seasons, would you recommend them, or look at the General Altimax instead?
cvxjet
Report this Post05-08-2022 01:24 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have used General tires on my Fiero quite a lot over the years (37)......I actually have General G-Max on my Fiero now...But I do have the AltiMax on my van...Believe it or not, I have drifted the van through a few cloverleafs. I outran a dumb kid in a riced-out civic on a windy road, also.
No, they are not the stickiest tire- but they are much better than ANY tire you could buy in the 80s.
Originally, I was running 215/60-14s on my 85 SE V6......I switched to 205/60-15s up front and the steering feel and easy of steering at low speeds was improved...Later, I switched again to 16 x 7s with 205/55 and 225/55 size tires. I can scare the absolute crap out of anyone riding with me with how quick my car can get around a turn.
Total ratings: 207
Report this Post05-08-2022 06:45 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are better tires out there than what I currently have on my car. I have heard good things about General, Continental and others.
From experience, Cooper makes great tires, and I will likely go with those when I buy new tires for the Formula, but they will be 17's to fit the summer wheels.
cvxjet
Report this Post05-08-2022 12:05 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I checked out Coopers before my last Fiero tire purchase; They are heavy like the BFGs....General does make a G-Max (The G-Max RS) that is a summer tire. General is owned by Continental, and both companies make tires that are lighter than most and perform as good or better than other manufacturers.
Just checked on TireRack; In my rear size (225/55-16) the General G-Max AS-05 weighs 23 lbs while the Cooper Zeon weighs 27 lbs...That is 4 lbs and mainly out at the edge so it would have a huge effect on performance.
