  Sea Foam
Sea Foam by hunter29
Started on: 04-29-2022 02:28 PM
Replies: 21 (508 views)
Last post by: robmox on 05-12-2022 01:51 PM
hunter29
Report this Post04-29-2022 02:28 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is SeaFoam bad for the injectors or anything else in our old cars ?
Total ratings: 207
Report this Post04-29-2022 02:31 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
No. Just no.
I would never use Seafoam.
No.
hunter29
Report this Post04-29-2022 02:35 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
That’s why I asked, since my car sat for 29 years I was wondering if I should run some kind of cleaner , not that I need it, but figured it wouldn’t hurt, unless???
Total ratings: 207
Report this Post04-29-2022 05:47 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
It wouldn't hurt to run the proper amount of Lucas fuel injector cleaner in your gas tank for 3 or 4 tanks.
It will clean the injectors, the fuel lines and intake valves over a period of time.
If you run good quality oil (Valvoline), the lubrication system will also clean up with periodic oil changes.
No need to run synthetic oil, but a quart of Lucas Oil Treatment will help the front and rear main seals and slowly dissolve any gunk in the oil system.
Use a good quality oil filter (WIX) and change the oil every 3000 miles for the first couple of oil changes, then go to every 5000 miles.
hunter29
Report this Post04-29-2022 05:58 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, 13k original miles, use Wix and M1 E free gas
[This message has been edited by hunter29 (edited 04-29-2022).]
Total ratings: 207
Report this Post04-29-2022 07:50 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
hunter29
Report this Post04-29-2022 08:20 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
At 300 miles a year I won’t have to change the oil for ten years…lol
Now I just have to find this tick sound and I’m beginning to worry it’s not the exhaust..
Xenoblast
Report this Post04-29-2022 08:38 PM Click Here to See the Profile for XenoblastSend a Private Message to XenoblastEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its good for when there is a lot of carbon deposits in your engine, but I wouldnt keep it in the oil for more then a couple hundred miles. I think most people go one tank of gas of hard driving with it before changing the oil. The nice thing about seafoam is that it can be used in the oil and gas tank.
Total ratings: 207
Report this Post04-29-2022 08:53 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not a Seafoam fan, at all.
sledcaddie
Report this Post05-02-2022 10:44 AM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, what is the issue with Sea Foam? Why is one fuel additive okay, but another is not?
skywurz
Report this Post05-02-2022 12:56 PM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
IDK for me Ill use Sea Foam Spray for use on a high mile engine while its running. You spray it into the intake while running at 1500 RPM. The cat has to be removed at this time or you will just clog it. I have had it drop a car 200 NOX points on the emissions. Running it in the oil i would not. Running as a Fuel stabilizer meh maybe. running it as a cleaner meh maybe. Id not expect magic results from it in the gas. Sea Foam is sold as a swiss army knife with a fold out hammer... Just buy a hammer. Its all mostly snake oil anyway.
Xenoblast
Report this Post05-03-2022 12:47 AM Click Here to See the Profile for XenoblastSend a Private Message to XenoblastEdit/Delete MessageReply w/QuoteDirect Link to This Post
If your engine is well taken care of, you probably wont have any benefit of using seafoam. If it is not however, you may get some results from it, and its one of those "why not" moments. See project farms video on it to see some positive results from using it.
https://youtu.be/agAWXnT4-EQ
For why people dont recommend it, is because it can clog up your cat, which is why I used it straight piped. Also one of my friends with a miata used it, and his car dieseled for a couple seconds while spraying it, so be wary of that.
[This message has been edited by Xenoblast (edited 05-03-2022).]
Total ratings: 207
Report this Post05-03-2022 07:09 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The O/P's car only has 13,000 miles on it.
steve308
Total ratings: 59
Report this Post05-03-2022 09:38 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
For what it's worth.... Seafoam and many other engine cleaners are solvent based. There are detergent based cleaners that are 'cat' friendly and less harmful to injector seals and other components. Berryman products come to mind.
Rhodesia1977
Report this Post05-07-2022 09:57 PM Click Here to See the Profile for Rhodesia1977Send a Private Message to Rhodesia1977Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've heard too many bad things about Seafoam. I have been using Purple additive in my tank (1986 GT) and have had no issues for a few years now. Scotty Kilmore recommends it.
Total ratings: 207
Report this Post05-07-2022 10:47 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've watched his videos, the man is an idiot.
Total ratings: 328
Report this Post05-09-2022 05:15 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the best way to clean injectors on the car is to use an injector cleaning kit. One that attaches a pressurized can filled with professional grade injector cleaner to the fuel rail. You pull the fuel pump fuse, apply air set for 43 psi of pressure and run the can of cleaner through the injectors until finished. Some of the in-tank cleaners are not bad but they take a while to work.
As for Kilmers and many other advise provided on You Tube they are paid endorsements. The products could contain piss and the spokesperson would say this will make you car like new again.
Total ratings: 207
Report this Post05-09-2022 06:41 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only time a car should need injector cleaning is after sitting for a very extended period of time.
Short term storage it doesn't hurt to run a few tanks with in-tank injector cleaner.
Rule of thumb - don't use discount gas station fuel, only buy quality gas from places like Shell or other name brands.
RichLo1
Report this Post05-12-2022 10:59 AM Click Here to See the Profile for RichLo1Send a Private Message to RichLo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
The BEST way to clean injectors is to remove them and put them in an ultrasonic bath for 30min-1hr and flow test them before and after. There are many services that can to this, you can ship them out if you dont have anybody locally. Usually about $25per injector.
Total ratings: 461
Report this Post05-12-2022 11:07 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
And an annoying one, at that.
You're the first person I've ever heard that didn't like Seafoam. (I've only used it once. Didn't make much of a difference.)
Total ratings: 207
Report this Post05-12-2022 12:11 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are no 'one size fits all' automotive additives, but seafoam tries to be.
It's the WD-40 of automotive chemicals, and I think WD-40 sucks too.
robmox
Report this Post05-12-2022 01:51 PM Click Here to See the Profile for robmoxSend a Private Message to robmoxEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by olejoedad:
You prefer Lucas over competitors like Berrymans'? They claim that Berrymans B12 is good for both cleaning your fuel system and injectors, so I was planning on running that in the Formula you were answering my questions about.
