  F23/3800 Spec 3 clutch question
F23/3800 Spec 3 clutch question by cam-a-lot
Started on: 04-25-2022 11:51 AM
Replies: 3 (431 views)
Last post by: Will on 05-03-2022 11:22 AM
cam-a-lot
Total ratings: 97
Report this Post04-25-2022 11:51 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone have the correct torque specs for this? Clutch didn't come with any install instructions
Reached out to SPEC, but was wondering if anyone here has the info
thanks
hnthomps
Total ratings: 50
Report this Post04-25-2022 12:36 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I do not remember the exact max torque specifications but do have a SPEC Stage 3 clutch coupled to a Getrag 282 and a 3800 SC Series II. I am generally happy with this but would get a SPEC Stage 3+ if I had to do this again. It is supposed to be a bit less on/off and thus more "streetable".
Nelson
Total ratings: 461
Report this Post05-01-2022 11:58 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Were you talking about bolt torque readings?
Factory says 15 lbs, for the pressure plate bolts. (Yeah. I know. I thought it should be more, too. Stretched the hell out of my first set of bolts. )
https://www.fiero.nl/forum/...070315-2-077940.html
[This message has been edited by Raydar (edited 05-01-2022).]
Total ratings: 236
Report this Post05-03-2022 11:22 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dunno what the flywheel bolt torque spec is.
15 ftlbs is perfectly fine for the pressure plate to flywheel bolts. Because the radius of the bolt circle is so much larger, that joint hand handle all the torque it needs to handle, even with smaller lighter bolts.
