  Oil pressure sensor wiring on 3800 SC
Oil pressure sensor wiring on 3800 SC by TurboGN
Started on: 04-23-2022 10:49 AM
Replies: 20 (394 views)
Last post by: Trinten on 08-23-2025 10:58 PM
TurboGN
Report this Post04-23-2022 10:49 AM Click Here to See the Profile for TurboGNSend a Private Message to TurboGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 1988 Fiero GT with the L32 swap. The oil pressure gauge is pegged and I found there are no wires going to the oil pressure sensor. Some info I found says I have to run a wire from the C203 Tan wire down to the center pin of the oil pressure sensor. I looked at the C203 and I don't see a Tan wire. Where do I go from here?
Report this Post04-23-2022 11:15 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to add a wire to the C203 engine side.
Or you could tap into the wire on the chassis side C203 and run it to the OPS, but that wire couldn't be unplugged with the connector if you needed a cradle drop.
The C203 pin designation is 'E' for the OPS signal.
Sounds like your harness builder didn't do a very good job.
Typical swap harnesses also use the OPS circuit as a backup power feed for the fuel pump, utilizing an 88 OPS or similar. This circuit is included in case the Fuel Pump Relay fails.
[This message has been edited by olejoedad (edited 04-23-2022).]
TurboGN
Report this Post04-23-2022 11:47 AM Click Here to See the Profile for TurboGNSend a Private Message to TurboGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the information. The previous owner used a 2003 Lasabre wiring harness for some reason. Seems like it makes everything more difficult.
TurboGN
Report this Post04-25-2022 08:03 PM Click Here to See the Profile for TurboGNSend a Private Message to TurboGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well it just got worse. Apparently the previous owner must have ripped out the wiring on all the connectors and then just put them in where he felt like it, or trying to match the 2003 Lasabre harness. I went to C203 and where the Tan wire should be for the oil pressure gauge there is no wire at all. I clipped onto the pin below it and that's not the correct wire either.
I then moved on to the same problem with the AC not having any wiring and once again at the C203 both the spots where there should be the AC clutch, and AC request, there is no wire at all.
Report this Post04-25-2022 08:50 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you want the harness repaired and to be fully functional, we should talk.
I build and repair harnesses for Fiero swaps and other vehicles as well.
You wouldn't believe some of the crap jobs I've had to make right.
PM me if you are interested.
[This message has been edited by olejoedad (edited 04-25-2022).]
TurboGN
Report this Post04-25-2022 09:08 PM Click Here to See the Profile for TurboGNSend a Private Message to TurboGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank's, I'll have to go through the whole thing and see if I can get the last few things working or if the whole harness has to be redone.
I just can't quite figure out why they would change all the wire placements, it seems it would make it harder for them to do the swap.
How much do you charge for a full re-work?
[This message has been edited by TurboGN (edited 04-25-2022).]
Report this Post04-25-2022 10:43 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
As I said, you wouldn't believe some of the crap that has come across my work table.
This conversation should move to PM or email.
My email is in my profile.
MulletproofMonk
Total ratings: 78
Report this Post04-26-2022 03:38 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
My memory is that I had to add a pin to the oil pressure connector because the LeSabre has a idiot light, not a gauge.
According to my information:
Oil Sender pin A to C203 pin E
Oil Sender pin B empty
Oil Sender pin C to Engine Block Ground
Oil Sender pin D to PCM C2 pin 19
Edited EDIT:
I believe that I had to either use the oil sender plug off an 88 motor or pull one off a 91-94 Cadillac 4.9L at the junkyard because the LeSabre only had the 2 pin spots.
EDIT:
I have a 1999 LeSabre motor that I just bought Sunday sitting here in the garage... I went and took a picture. Memory is still good.
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
[This message has been edited by MulletproofMonk (edited 04-26-2022).]
MulletproofMonk
Total ratings: 78
Report this Post04-26-2022 03:47 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
MulletproofMonk
Member since Oct 2005
Also I would recommend Joe if you aren't going to do it yourself. He's been around a long time, hasn't had any issues that I have seen on here and gives plenty of free advice. He and Ryan would be my go-to's.
It is fairly easy to do if you are organized and patient. If you start cutting wires just trying to poke around, you are going to be in worse shape... and better off to pay for it upfront then later...
Report this Post04-26-2022 05:12 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The backup fuel pump power circuit is not wired per you info, Brian.
Pin A does indeed go to C203 E for the gage.
C and D go to C203 B and L.
MulletproofMonk
Total ratings: 78
Report this Post04-26-2022 08:38 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, that is interesting, because that is what i have on my sheet... i did a strike on it to not spread the wrong information...
Report this Post04-27-2022 08:10 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
TurboGN
Report this Post04-27-2022 09:06 AM Click Here to See the Profile for TurboGNSend a Private Message to TurboGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all the great information guys.
I pulled the oil pressure gauge and followed the Tan wire which ends at the C203 as a Whiteish wire (maybe color change due to age?) that is in the "C" pin with no wire on the opposite side. I spliced into that wire but still had a pegged gauge. I switched to a 1988 oil pressure sensor and it now works. I seem to think that I am going to be running into this kind of stuff on the last two items, A/C & Cruise control.
Report this Post04-27-2022 11:40 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 'C' pin on the C203 is for the malfunction indicator light in the instrument cluster.
The 'C' pin on an 88 OPS is for the fuel pump relay backup circuit.
The 'A' pin on the 88 OPS should be attached to C203 on the 'E' terminal.
Are you sure your posting doesn't have a typo error in it?
TurboGN
Report this Post04-27-2022 09:25 PM Click Here to See the Profile for TurboGNSend a Private Message to TurboGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're right, it should be "D" not "C", and there was no wire coming out.
Trinten
Report this Post06-03-2025 11:52 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
A friend is running into this same problem with his 3800 swap. His swap was done into an 86 GT. He is having the same issue you are (oil pressure gauge pegs as soon as the car starts up). He confirmed the pressure sender is going to the tan wire.
The oil pressure sensor he installed is for a Fiero. AC Delco part C8020, GM part # 19106700. Which looks like it's for the 87. Besides the connector being different on the one for the 88 (looks like GM part number D1808A?) did you have any other issues with switching to this connector?
Thanks
jelly2m8
Total ratings: 242
Report this Post06-04-2025 01:07 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Deleted, question was answered.
[This message has been edited by jelly2m8 (edited 06-04-2025).]
Report this Post06-10-2025 05:23 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
After reading all this, I'll check my harness connections again. My oil pressure gauge always read toward max but I recall leaving the oil pressure sensor connection attached on the 2003 GTP harness and just wiring it in. Time to recheck.
Jncomutt
Total ratings: 221
Report this Post06-11-2025 08:22 AM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
C8020 appears to be a switch, not a sending unit for a guage. That one closes at 9 PSI. Near zero ohms (which is same as shorted like he has) pegs the guage, makes sense he sees that. High resistance (90-100ohm) would put the guage around zero and cause light to come on.
Report this Post06-12-2025 09:28 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The problem here and it shows on my 3800SC as well may not be the wiring but the sensor itself. Most of the OPS units on Rock Auto show a 2 pin pressure light switch. Although the wiring may be correct you may not have the correct oil pressure sensor but one that just triggers the idiot light.. I am running a 2003 PCM and harness with all the original connections including the power center. Does anyone know the correct sensor part number that will drive the Fiero gauge correctly??? Even the 88 2.8 L OPS have come through wrong.
Trinten
Report this Post08-23-2025 10:58 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you! And yes. It's frustrating how "switch" and "sender" are interchangeably used for this part across various retailers.
Also my apologies to everyone, I keep forgetting PFF doesn't auto-sign you up for reply notifications when you post (or, if it's an option for it to always do that, I don't have it turned on).
We did get the '88 sender after some more Searching here on PFF. For those who may need it, the GM Part number is GM1808A, alternative: SMP PS262 (This is the one we got for his car a month or so ago, and put into my car today). and SMP PS245 These are the 3 pin "skinnier" ones. Source for part numbers: our good friends at Rock Auto.
