  Electric Trunk wire info needed
Electric Trunk wire info needed by str8maxn
Started on: 04-06-2022 02:07 PM
Replies: 15 (544 views)
Last post by: str8maxn on 04-18-2022 03:06 PM
str8maxn
Report this Post04-06-2022 02:07 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello All,
Can someone provide some info on how the wire that connects to the electronic trunk release is routed and what the connects looks like?
My Fiero has an LT1 swap and all I have it a single cut wire hanging from the rear deck lid that routes to the rear trunk release. when I provide power to the wire the actuator pops the trunk.
Should I not be able to find the original connector and If I had to route a new wire from the rear deck lid to that stock fiero trunk switch what wire on the connector would I need to tap?
Total ratings: 154
Report this Post04-06-2022 03:36 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stock setup used a flat 3 or 4 pin connector at the right trunk hinge. The wire to the release solenoid was routed through the decklid reinforcement rib. There is a small hole in the rib near the hinge. I installed a release into a base 88 coupe by using a piece of single strand uncoated aluminum wire inserted at the solenoid end, pushing it down to the hinge area, then snaking the single wire back through. I had clipped a terminal from a piece of scrap harness, spliced it to the wire and inserted it into the stock harness connector.
That wire would be the hot wire when the release button is activated. The solenoid grounds through the latch and loop on the body. At least 2 of the wires running through the connector and deck lid rib are for the trunk light switch. If the car didn't originally have a trunk release, one of the cavities on the trunkside harness will be vacant. That's the one for the solenoid power wire.
str8maxn
Report this Post04-06-2022 04:22 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like my actuator stop working now. I can't get it to active anymore. Wonder if some how I messed it up during my testing. If I choose to run a new toggle switch to it do I need a relay?
Report this Post04-06-2022 06:34 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
It depends on year of car and trans...
84 is different and doesn't use relay. Switch goes direct to solenoid.
85 has relay but lid is wired different
86-88 has relay have 4 pin connector at right hinge.
85-88 Interlocking Relay wiring depends on trans type.
If you change auto to stick or maybe other way then likely someone rewired this part.
Quick test put jumper on the solenoid and frame/engine then push lock switch. The solenoid won't work w/o grounding the solenoid body.
See my Cave, Trunk Release
[This message has been edited by theogre (edited 04-06-2022).]
Total ratings: 207
Report this Post04-06-2022 06:46 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year, engine and trans was your car built with?
I probably have diagrams.
Total ratings: 154
Report this Post04-06-2022 08:54 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Clamp a jumper cable to the solenoid and the trunk latch loop then briefly apply power. If it's good it will click.
str8maxn
Report this Post04-06-2022 11:48 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a 1985 I am not sure what engine the fiero had before the LT1 swap. It did have an 80 MPH speedo if that helps any.
str8maxn
Report this Post04-06-2022 11:57 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
str8maxn
Member since Aug 2018
OK .. I got the actuator \ solenoid to work again. I had to ground it and provide power for it to work.
Here is what my lower drives side looks like near the trunk hinge.
[This message has been edited by str8maxn (edited 04-06-2022).]
Report this Post04-07-2022 08:49 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Plug is likely deleted AC Clutch relay same as other relay there and not used w/ Power Latch.3
Latch Relay is under the dash and very different type.
OE 85 C402 is near there has blk/wht wire.
I don't have pic/note saying what type connector used.
Think might be 1 pin weather pack same as OE O2 sensor but flipped so factory can't confuse them and plug in wires wrong.
Next thing is C500 pin A1 when turn back to black wire in car side to the relay plug under the dash.
Is likely someone hack the wiring to add PL and other 1/2 is hanging down and worse now melted if hits the exhaust.
OE GM connectors are air/hydro crimped and never fall off the end to look like that.
Wire shown is way too short. Rubber thing is "seal" where wire goes into the lid and wire need to reach the other part connect w/o pulling that when lid open/close.
[This message has been edited by theogre (edited 04-07-2022).]
Total ratings: 207
Report this Post04-07-2022 11:12 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
As luck would have it, but he only FSM I don't have is for the 85.
Sorry.
str8maxn
Report this Post04-07-2022 11:15 AM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you all ... I think I have enough info to proceed.
On to the next issue.
str8maxn
Report this Post04-18-2022 11:47 AM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello all,
I was able to get electric trunk switch working. However, the trunk remains locked after pushing the switch.
How do I adjust the trunk lid to provide enough upward tension to keep the trunk lid open?
Do I need to add a door popper?
theogre - Added the missing Relay and the AC compressor still doesn't turn on... Any troubleshooting suggestions?
Total ratings: 207
Report this Post04-18-2022 12:53 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check refridgerant pressure.
str8maxn
Report this Post04-18-2022 01:11 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good point ... May need to stop at AutoZone for a owner tool.
str8maxn
Report this Post04-18-2022 02:40 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
str8maxn
I found an old thread about some adjustment screw that put upward tension on the trunk lid. I'll give this a shot later today.
https://www.fiero.nl/forum/Forum2/HTML/145254.html
str8maxn
Report this Post04-18-2022 03:06 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
str8maxn
trunk popper issue resolved ...... just needed to adjust the rubber screws.
