You "Claim" is only HL bulbs and Turn light cause this is Wrong.
Dash gauge reading 13v w/ engine running
is Low Volts and is
Not Normal even for 84 Fiero.
Tack bouncing is common because used same power and ground in the dash as volt gauge and more.
Even if a dash gauge reads wrong... You can't trust them to find the problem.
Use a real meter on Battery, alt output, and other places.
Should see ~ 12.6-13 engine off w/ full charge battery, 14.5-15 engine running.
Engine and body has many "ground" bolted/screwed to them, between frame and engine, and more in engine bay, in cabin, in front of car.
Not all "Grounds" are power grounds but return lines like for ignition and "one wire" O2 sensor.
1 large ground between engine and frame carries major Alt Ground and often have problems or is gone.
Iffy Alt Sense wiring can do similar as bad grounds or cause high volts.
Alt Output Goes Thru 84 Fiero C500 in a round about way and crap connection there can Burn Down your car.
Link A and C500 E4 runs Most of the car including the dash, ECM, Engine, AC and Heater, other Lights like the turn and brake lights.
Only HL Bulbs and Motors get power by Link B connected to the starter same way as Link A covering in Alt Sense page.
(Link splice w/ Alt Out says goes to EFI is only Standby Power to save ECM code(s), radio clock and setting.)
read wire service but location(s) of whatever maybe different or don't have for 84.
If you can't find 84 data elsewhere... go to alldatadiy.com to get
Correct Data For 84 Fiero. They have Same Data as GM FSM unlike crap Haynes and others.
If someone have "modified" the wiring... you likely still need same to find just what they did and is it safe.
Once you find this problem... Continue cleaning/fixed grounds. Crap grounds often cause Dim HL bulbs and more problems.
| | | quote | Originally posted by olejoedad: The 84 doesn't use a Battery Junction Terminal. |
Yup. Some people can't be bother most 84 Fiero wiring is different then later years.
Like Has the Same problems in other GM vehicles w/ fusible links to the starter causing problems and alt output and others going thru C100 that = to C500 in 84 Fiero. The links and ends mounted so low often get dirty/rusty, cooked by exhaust, and worse. 84 Fiero, V6 and V8 front engine vehicles have exhaust running near them and Road salt etc can eat them.
These need same cleaning as grounds above. If ends or links are "bad" then must Replace Them right or expect more problems.
