Sadly a "bad ground" causing DTC 42 isn't rare. Related are Ref and EST Wires between ICM and ECM often have same problems.
More the "bad ground" likely isn't a power ground that most think...
See my Cave,
Ground "Myth" notesIOW If the "Fake Ground" or the Reference wire(s) have problems you often get Code/DTC 42 "Electronic Spark Timing" to engine not running because ECM won't turn on fuel injection.
Worse the Exact "Fake ground" and other pins on ECM often changes for each version of ECM used for a given engine. Example: For Fiero...
code:
Engine "ground" Ref EST
L4 Dist Black 3 Black 2 Black19 (Colors = plug color)
L4 DIS Black 16 Black 9 White 6
V6 Dist B3 B5 B4 (I think B section is latch side of Small plug)
Note that 87-88 L4 DIS w/ DTC 42 can be problems w/ the PROM but you need to check the wires, pins, etc first.
Loose ECM pins like above is why this ECM plug version has pink "TPA" looks like a cover on the plug. All TPA are "backup" to stop pins backing out. (See my Cave,
Terminal Access)
ECM has 1 or more "Real" Power Ground
But Another Fake Ground is a Tan "Ground" bolted to the engine that is actually a Return Line from the "One Wire" O2 sensor.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 03-13-2022).]
