  Using a Vacuum Brake Bleeder
Using a Vacuum Brake Bleeder by RotrexFiero
Started on: 01-13-2022 06:14 PM
Replies: 9 (216 views)
Last post by: mafv8 on 01-14-2022 04:03 PM
RotrexFiero
Report this Post01-13-2022 06:14 PM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay, I purchased one of these but have had no luck using it. I just get bubbles of air.
I read that it's pulling air from around the bleeder screw. And, I read either you have to put grease on the screw or teflon tape to seal it. Is this true?
Or, is it pulling air from somewhere else.?
Or, should I forgo this method?
My brakes are just too mushy!!!
Any wisdom appreciated.
ltlfrari
Total ratings: 127
Report this Post01-13-2022 06:59 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I never really had any success with a vac bleeder, same problem, air getting in. What you need are so called "one man bleeders" that have a spring loaded ball valve in the bleeder itself. Work great, even better than the two man open, push, close, release, repeat method of old.
Dave
www.ltlfrari.com
Mike in Sydney
Report this Post01-13-2022 07:11 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed. Speed bleeders are great. Replace the old bleeder nipple with the speed bleeder, put a clear hose on the bleeder and the end in a jar of brake fluid (so you can see the air bubbles), crack open the bleeder 1/2 turn and pump the pedal until no more air bubbles come out.
RotrexFiero
Report this Post01-13-2022 07:15 PM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a source for these that fit the Fiero? The speed bleeders.
ericjon262
Report this Post01-13-2022 07:25 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've never had acceptable luck with speed bleeders, I have however fallen in love with Phoenix reverse bleeders. They pump fluid in the bleeder and out the master, the brakes on my truck have been trash for years, this was the first device I have used to successfully get all the air out.
https://www.speedwaymotors....CSE)%20(Bing)&utm_te rm=4577404346894399&utm_content=All%20Products%20(Feb28_2020)
cognita semper
Mike in Sydney
Report this Post01-14-2022 05:15 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
double post omitted
[This message has been edited by Mike in Sydney (edited 01-14-2022).]
Mike in Sydney
Report this Post01-14-2022 05:17 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mike in Sydney
Member since Sep 2011
The Fiero Store, Advance auto, Pep Boys, Summit, Rock Auto, etc. Just about any auto parts store.
Report this Post01-14-2022 10:24 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Using a Vacuum Brake Bleeder"
Vac bleeding often needs "sealer" for bleed screw.
Take bleeder out, coat screw threads w/ some Brake Grease, then put screw in nearly all the way to close. Leave "runoff" grease that pushes out of threads alone during bleeding.
Should solve your air leak problem and act as anti-seize later.
"Speed bleeders are great."
Sadly Not.
They hold brake fluid under the ball that draws a huge amount of water then the water often attacks the screw and caliper shell welding the screw in the hole.
If you find a way to stop that, "water" carrying road salt and other pollution will have more things to attack and have same problem. Even worse for people don't use bleeder caps.
I'll never recommend them to anyone except maybe race people that bleeds the system a lot per season.
Report this Post01-14-2022 12:27 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most of our Fieros are show or hobby cars. I have tried all brake bleeding methods and have settled on the Russell speed bleeders P/N 639580. I bleed every season and have never had a problem.
Have had decent luck with the vacuum bleeder but as Theocre has mentioned you need to get a good seal on the bleeders. I have used Teflon thread sealer with success.
mafv8
Report this Post01-14-2022 04:03 PM Click Here to See the Profile for mafv8Send a Private Message to mafv8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have used the Motive Products bleeder, you pump it up like a garden sprayer, and it forces fluid through the system via the master cylinder reservoir, works great. Hardest part is getting the adaptor seated and sealed on the reservoir, pump it up then open up the bleed valves.
