  Loss of performance, overheating, severe coolant leak, then it's fine?
Loss of performance, overheating, severe coolant leak, then it's fine? by 842m4SE
Started on: 01-09-2022 10:29 PM
Replies: 5 (374 views)
Last post by: cvxjet on 01-10-2022 04:03 PM
842m4SE
Report this Post01-09-2022 10:29 PM Click Here to See the Profile for 842m4SESend a Private Message to 842m4SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
On my 84 Duke I was having a great country twisties drive today, going about an hour with multiple stops to check on the engine and other vitals, all good.
But near (-at) the end of the drive, I had a severe loss in power, felt like it was misfiring or chugging, and shortly after it started overheating to just before the red- then I heard some loud bangs and I quickly pulled over and shut it off.
Checked the frunk and there was coolant all over the radiator, lid, headlights, etc....... but no burst coolant pipes and the expansion tank was reading exactly correctly full, and I heard some loud gurglings shortly after that stopped quickly.
At this time also some smoke was coming from the rear decklid- checked it and looked like it was coming from the rear of the valve cover near the exhaust manifold.
Got a ride and came back about 30 mins later with a tow but it started right up and went a few miles speedily without any drama besides a coolant temp spike that settled down.
I'm very confused... what could've caused this?
[This message has been edited by 842m4SE (edited 01-09-2022).]
Report this Post01-10-2022 12:18 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
No Obvious Leaks...
Cap maybe is bad.
See my Cave, Radiator Caps
Find or get tested for exhaust in coolant.
Test uses a liquid that change color when true.
When True then have engine problems... bad head gasket to a lot worse.
See my Cave, Do You Recall?
If is true 84 engine then can be "early signs" borked block etc. and Why many 84 had engine replace under warranty or recall jobs.
Report this Post01-10-2022 09:57 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
My guess. Blown head gasket. Do coolant check as described by theocre or do a pressure test. If OK replace the radiator cap but my money is on the head gasket. If it is the head gasket you can sometimes fix it with a block sealer but the process to seal the leak using this method can be critical. You must do it without the thermostat in place.
Report this Post01-10-2022 12:48 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
84 and other years for L4 w/ "bad Head Gaskets" can have bad Head Bolt(s) causing this and any sealer fix won't work.
GM put out TSB for just this problem because #2 H-bolt, E-side between cyl 2 & 3, are known to fail either weak or break.
So when fix, need a Head "Set" and new H-bolt set just for this reason.
Can get a head set/kit of new caskets but better to spend money to get best Permatex intake and valve cover gaskets or expect leaks w/ them days to months later.
cebix
Report this Post01-10-2022 02:49 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could also have leaking coolant into the intake through the intake manifold gasket/cracked manifold. That may cause surging/bucking too. If you're wondering where all that coolant came from in the frunk your overflow tank pretty surely overfilled and you spilled coolant everywhere in those turns through that cap which is basically an umbrella.
cvxjet
Report this Post01-10-2022 04:03 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 85 SE V6; I had a problem with overheating- caused by a new water pump that had a plastic impeller that would spin loosely on the metal shaft. At one point it would start overheating- I would pull over and check things, and see that the overflow tank had..."Over-flowed"...But even when I checked it quickly, the water level would be low. So the sudden boiling and overflow would happen very quickly- and subside very quickly.
I swapped in a METAL-impeller pump and stopped having problems. By the way, I was able to drive her home simply by removing the thermostat so that the water could flow freely and there was not much drag on that stupid plastic impeller...But be very careful removing the cap because if it is hot and under pressure......It can get you (I actually carry gloves for working on the car, etc)
