  powertrain swap
powertrain swap by larry mimbs
Started on: 01-09-2022 02:18 PM
Replies: 8 (424 views)
Last post by: ericjon262 on 01-31-2022 10:34 PM
larry mimbs
Report this Post01-09-2022 02:18 PM Click Here to See the Profile for larry mimbsSend a Private Message to larry mimbsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 88 2.5l automatic trans. with trans/diff problems that needs an upgrade. I have a 2000 Malibu with 3.1l auto. I have a pair of KKK turbos from a Porsche 996T 3.6l with internal wastegates. Just over 400 hp. Would that make a reasonable combination?
ericjon262
Report this Post01-13-2022 11:23 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would suggest going with a single turbo, one is difficult enough to install cleanly, 2 makes for headaches. the 3100 is almost a bolt in for a 2.8, you'll need to do some wiring, and unless you make a low mount alternator, or swap a 88 timing cover and run fiero accessories, notch the decklid.
cognita semper
Report this Post01-13-2022 12:48 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would exercise caution in a DIY turbo project. While you could probably get away with 5-6 lbs of boost an engine must be strong enough and tuned for boost. You just can't bolt a turbo on a used high mileage engine and go. Things like cam profile, variable timing retard under boost, fuel pressure referenced to boost and grades of fuel used, all will have a bearing. There is no way that you will get anywhere near 400HP with the combo that you are intending to swap.
pmbrunelle
Total ratings: 63
Report this Post01-13-2022 01:17 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
OP might get close, but he's going to need a lot more than the 5-6 psi boost you suggest.
I agree with the idea of doing a single turbo. A turbo install is a plumbing project; the less pipes you have, the easier it is!
Also, there's no replacement for displacement.
larry mimbs
Report this Post01-19-2022 11:24 AM Click Here to See the Profile for larry mimbsSend a Private Message to larry mimbsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I also have a couple of buick/olds/landrover aluminum v8s, but moving the starter to the other side is a major nightmare.
pmbrunelle
Total ratings: 63
Report this Post01-19-2022 12:19 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieroguru offers a bracket to install a starter on the bellhousing of a transmission:
https://fieroguruperformance.com/?page_id=1558
ericjon262
Report this Post01-20-2022 02:01 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
do they have the metric bellhousing pattern? I suspect they would use the BOP pattern, which would make any swap much more difficult.
cognita semper
larry mimbs
Report this Post01-29-2022 05:41 PM Click Here to See the Profile for larry mimbsSend a Private Message to larry mimbsEdit/Delete MessageReply w/QuoteDirect Link to This Post
The BOP/rover bellhousing is unique. Nothing else is close. I already made an adapter to bolt a GM metric transmission to the BOP block.
ericjon262
Report this Post01-31-2022 10:34 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
it's uncharted territory, which makes it interesting, not sure how practical or fast it will be when you're done though.
cognita semper
