  Surging idle
Surging idle by katie80
Started on: 11-19-2021 06:39 PM
Replies: 2 (657 views)
Last post by: cebix on 11-25-2021 01:49 PM
katie80
Report this Post11-19-2021 06:39 PM Click Here to See the Profile for katie80Send a Private Message to katie80Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 84 SE and the idle surges between 500 and 1500 rpm. it's not the iac as I have replaced it and it didn't change the symptom. if I give the engine a quick little tap on the gas it evens out the idle to around 800. the throttle plate has been adjusted by the previous owner. I adjusted it to the point where the engine seems to idle best. what is the correct way to adjust it? I think this is my issue.
Xenoblast
Report this Post11-20-2021 05:47 PM Click Here to See the Profile for XenoblastSend a Private Message to XenoblastEdit/Delete MessageReply w/QuoteDirect Link to This Post
cebix
Report this Post11-25-2021 01:49 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
After you adjust the throttle stop to original (should never be changed), check your EGR if it's working and if it's the correct part number - been there, done that.
EDIT: Oh and check for vacuum leaks with a cigar or something.
[This message has been edited by cebix (edited 11-25-2021).]
