  5-speed Transmission Leak
5-speed Transmission Leak by Mxzx
Started on: 11-18-2021 10:23 AM
Replies: 5 (505 views)
Last post by: fierofool on 11-18-2021 10:38 PM
Mxzx
Report this Post11-18-2021 10:23 AM Click Here to See the Profile for MxzxSend a Private Message to MxzxEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a pretty good leak and puddle after driving short distances. I know one shaft seal was leaking but this was coming from inside the bell housing, I figured it was the input seal. I pulled trans to find this! Any ideas what would cause the cover to come off, hard shifting? I just got the car so I have no idea if the trans was worked on previously.
Report this Post11-18-2021 12:03 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't assume it was the transmission. It could be the engine rear main oil seal. Not hard to replace with the proper tool.
Mxzx
Report this Post11-18-2021 12:38 PM Click Here to See the Profile for MxzxSend a Private Message to MxzxEdit/Delete MessageReply w/QuoteDirect Link to This Post
So that cap doesn't seal fluid from coming out?
87_special
Report this Post11-18-2021 01:51 PM Click Here to See the Profile for 87_specialSend a Private Message to 87_specialEdit/Delete MessageReply w/QuoteDirect Link to This Post
It does! Spread some rtv on the edge and smack it back it. Be careful when tapping it in. You can easily break the center of the puck. Use a block of wood or something. Refill with 2 bottles Penzoil or Valvolene Syncromesh AFTER axle reinstall. Good time to replace the axles seals also.
Check for oil behind the flywheel. Rear main seal and camshaft end cover gasket are sources of engine oil leaks.
Mxzx
Report this Post11-18-2021 02:55 PM Click Here to See the Profile for MxzxSend a Private Message to MxzxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, will do!
Report this Post11-18-2021 10:38 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you fully drain the trans, it requires at least 2.5 quarts to refill.
