  What is the black (grey) connector?
What is the black (grey) connector? by 72and86
Started on: 11-17-2021 10:46 AM
Replies: 15 (363 views)
Last post by: slicknick on 11-28-2021 01:23 PM
72and86
Report this Post11-17-2021 10:46 AM Click Here to See the Profile for 72and86Send a Private Message to 72and86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Replacing the radio back to period correct with a 1989-94 Pontiac radio. I got the harness all wired up.
Three questions;
1- car's antenna wont fit in back of radio now. What adapter is needed?
2- Any idea why the LED blue display doesn't work? (orange wire to orange, right?)
3- What is the black (grey) connector? coming out of dash? See pic
[This message has been edited by 72and86 (edited 11-17-2021).]
fierosound
Total ratings: 286
Report this Post11-17-2021 12:49 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Connector is battery power to radio memory and lighting.
There's a pigtail on the radio that plugs into it.
[This message has been edited by fierosound (edited 11-17-2021).]
72and86
Report this Post11-17-2021 02:22 PM Click Here to See the Profile for 72and86Send a Private Message to 72and86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks except my radio is a 1989-94 Pontiac radio and doesn't have the same connectors. But now at least I know the plugs functions. Thanks. Steve
Mike in Sydney
Report this Post11-17-2021 07:32 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Buy the harness for the 1989-94 Pontiac radio from replacementradios.com. It's prewired and the plugs from the Fiero wiring harness plug into it and it plugs into the 1989-94 Pontiac radio. No cutting or splicing. Well worth the money, IMO. I used it in both of my cars when I installed Monsoons in them.
Total ratings: 236
Report this Post11-17-2021 10:45 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC, there was a 90 degree adapter installed from the factory.
Mike in Sydney
Report this Post11-18-2021 06:19 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replacement Radios has the 90 degree antenna adapter, too. It came with the harness
Mike in Sydney
Report this Post11-18-2021 06:20 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mike in Sydney
Member since Sep 2011
Double post
[This message has been edited by Mike in Sydney (edited 11-18-2021).]
Report this Post11-18-2021 08:24 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is the wiring adapter you will need. Plug and Play.
https://replacementradios.c...80b311d8e1a21fecd011
72and86
Report this Post11-18-2021 10:03 AM Click Here to See the Profile for 72and86Send a Private Message to 72and86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks but as the OP says I have a 89-94 Pontiac radio that has a different harness, its not a "Fiero radio". The harness Im using is this one:
https://www.amazon.com/dp/B...dt_b_product_details
Its all connected and works fine. My question was about the display light.
As for the connector shown its integrated into the newer style harness. Thanks for that heads up.
[This message has been edited by 72and86 (edited 11-18-2021).]
Report this Post11-19-2021 08:30 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The adapter I linked is for GM 89 and up radios installed in 88 and prior vehicles. It's a no-splice harness. The factory harness plugs into one end, the other end plugs into the radio and it includes the harness for the memory and illuminaton.
72and86
Report this Post11-20-2021 10:29 AM Click Here to See the Profile for 72and86Send a Private Message to 72and86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Since I cant see the other end in your pic in the link, I doubt it would have worked. I have a 21 pin connector not 20 as in the listing.
Report this Post11-20-2021 02:28 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, your receptacle is a little different than my 2000 Grand Prix radios.
72and86
Report this Post11-20-2021 05:22 PM Click Here to See the Profile for 72and86Send a Private Message to 72and86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yup I have two radios like this. Just different enough to be a problem finding the right harness.
Report this Post11-21-2021 08:02 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Last night I did some searching and I also pulled one of my radios off the shelf. The difference is the upper right socket area of your image. My radios have 6 pins, yours has 7. Also, that socket is somewhat elevated on yours and is on the same level as the left socket on mine. I searched Replacement Radios for gm 21 pin and came up with the same harness I suggested and in the description, it said it was a 20 pin, sometimes called a 21 pin. But it doesn't match your sockets.
Not knowing what specific vehicle your radio came from, I went to Crutchfield.com and entered 21 pin adapter. 1990 Grand Am Coupe. This is what I came up with, but it won't work, either. https://www.crutchfield.com...Harness.html?tp=2977
May be that the only way to get the correct harness is cut one from a junk yard find.
cvxjet
Report this Post11-21-2021 11:02 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
You may be able to get a connector for your radio from the Junk yard, and then the adapter harness and splice the two together to create your own specialized adapter harness- so you don't have to cut up/modify your car's harness.
slicknick
Report this Post11-28-2021 01:23 PM Click Here to See the Profile for slicknickSend a Private Message to slicknickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Typically, the adapter kit would only have the six pin connector for the power, and then the two four pin connectors for the speakers. The seven pin (or six) is for external tape decks or CD players. They're all the same from like '89 to '02 across lines for swapping purposes if you're just using the head and no auxiliaries.
Notice how that kit in the amazon link only has the bottom connector and then one four pin connector for the top row. Thought if you're saying everything is in and fine without that lighting connector, I'm not sure how you have it wired up.
