"Smaller" alt = less power, even lower then advertise amps because that is Peak Amps.
You likely have AC because 93 amp alt so can have other problems w/ AC on.
See my Cave,
Watt StoryVolts Going High then first thing connect real meter and drive if needed w/ that. Use extra wire(s) to read volts at battery w/ meter in the cabin. Make sure extra wires can't short or battery will dump > 100 Amps causing a fire.
Do Not trust a Dash Meter/gauges when have problems.
Check ECM "codes" too. If too high for > 2 sec can set DTC 53
If both alt's get same problem is likely wiring problem.
Like Iffy Side Plug can easily cause this.
Because Side plug is how regulator read alt output.
See my Cave,
Alternator SenseAlt ground is the alt case and mounting parts. Sometimes Iffy ground(s) can freak out the alt regulator too.
