  Car cranks but won't start
Car cranks but won't start by billybacon
Started on: 11-10-2021 12:54 AM
Replies: 7 (530 views)
Last post by: Forrest on 11-11-2021 07:31 AM
billybacon
Report this Post11-10-2021 12:54 AM Click Here to See the Profile for billybaconSend a Private Message to billybaconEdit/Delete MessageReply w/QuoteDirect Link to This Post
My car turned off at a stop sign and wouldn't turn back on. My gas indicator is known to act up, so I started there and got it a gallon of gas. That initially worked and got the car to the gas station and back. I noticed when i filled it, though, it didn't put in 9, gallons, it put in 4, meaning it had gas in it, already. After I got it back to my driveway, it wouldn't turn on again. It will turn over, and I can hear the fuel pump start and stop normally on the run position. I don't know engine stuff too well and I can easily get lost looking at some of the guides in the manual, but it's something I've been meaning to learn. How can I diagnose and fix this?
Xenoblast
Report this Post11-10-2021 01:05 AM Click Here to See the Profile for XenoblastSend a Private Message to XenoblastEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the tachometer move while cranking? If not, replace the ICM
Total ratings: 463
Report this Post11-10-2021 01:40 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doesn't mean that there's necessarily enough (or any!) fuel pressure. Check the fuel pressure with a tester and/or try starting the engine using starting fluid. If it starts, you've got a fuel delivery issue. If it still doesn't start, you've probably got an ignition issue, and if so, it's often the ICM (see previous post) that's failed.
[This message has been edited by Patrick (edited 11-10-2021).]
eti engineer
Report this Post11-10-2021 09:27 AM Click Here to See the Profile for eti engineerSend a Private Message to eti engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Get some starting fluid and spray it into the air intake. If the car starts and then stops, you have a fuel delivery problem. If not, you have an ignition/electrical problem. This will point you in the right direction as far as where you need to be looking...
Report this Post11-10-2021 11:33 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
What Engine?
Example:
L4 first check is look into oil fill hole and watch rockers move while someone else starts the car.
No move = very likely timing gear failed.
billybacon
Report this Post11-10-2021 05:20 PM Click Here to See the Profile for billybaconSend a Private Message to billybaconEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre:
What Engine?
Example:
It's a rebuilt iron duke at ~50k miles.
billybacon
Report this Post11-10-2021 06:40 PM Click Here to See the Profile for billybaconSend a Private Message to billybaconEdit/Delete MessageReply w/QuoteDirect Link to This Post
billybacon
Member since Jun 2021
Where should I spray the starter fluid? Just in the little hole near the air filter?
Forrest
Report this Post11-11-2021 07:31 AM Click Here to See the Profile for ForrestSend a Private Message to ForrestEdit/Delete MessageReply w/QuoteDirect Link to This Post
Get in the car and start it while pressing the gas.
Have someone spray starting fluid in here.
