  C&C T-top locks
C&C T-top locks by DanMFiero88
Started on: 10-28-2021 09:48 AM
Replies: 4 (445 views)
Last post by: Raydar on 10-30-2021 10:39 PM
DanMFiero88
Report this Post10-28-2021 09:48 AM Click Here to See the Profile for DanMFiero88Send a Private Message to DanMFiero88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi everyone,
I have a question about C&C T-top locks. Does a separate key open those locks, or is the ignition or trunk key supposed to open them? I was able to pop one lock with one of the keys, but I'm starting to wonder if that was a fluke. I can't get either key to seat in either lock now. Yes, I managed to lock the one that I opened up...
Thank you in advance!
jjd2296
Report this Post10-28-2021 11:44 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
It’s a separate key. At least it is for mine.
DanMFiero88
Report this Post10-28-2021 03:37 PM Click Here to See the Profile for DanMFiero88Send a Private Message to DanMFiero88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you - I suspected that was the case. I may have found a replacement key source online. At least, I hope that it is the correct key replacement.
eti engineer
Report this Post10-30-2021 09:35 AM Click Here to See the Profile for eti engineerSend a Private Message to eti engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by DanMFiero88:
Hi everyone,
Mine is a separate key, too. My T-tops have never been on the car, since I have owned it. They are in storage. I live in CA and the car has always been in the garage except for sunny days which happen most of the time. It has not seen a drop of rain in years. But once I get the cracked exhaust manifold replaced, I think I will sell it.
Total ratings: 461
Report this Post10-30-2021 10:39 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
True. And it's also a very common key.
I bought a T-top car without keys for the T-tops. I tried the key to my camper shell. Worked perfectly. Probably a lot of filing cabinet keys will work, too.
The key code may be stamped in the end of the lock cylinder. Most locksmiths should be able to recognize and duplicate it.
