  NO Highest Fan Blower Speed!
NO Highest Fan Blower Speed! by 72and86
Started on: 10-22-2021 07:39 PM
Replies: 6 (586 views)
Last post by: Raydar on 10-24-2021 12:04 PM
72and86
Report this Post10-22-2021 07:39 PM Click Here to See the Profile for 72and86Send a Private Message to 72and86Edit/Delete MessageReply w/QuoteDirect Link to This Post
From the "Now what"? files...
Today NO Highest Fan Blower Speed! I have the 3 medium/lower speeds but but highest speed is gone. Nothing. Is it a relay for high sped fan? If so where? Thx.
Report this Post10-22-2021 07:58 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Relay in front on heat/ac "box."
See 88 GT Heater Fuse Blown https://www.fiero.nl/forum/Forum2/HTML/145503.html
Total ratings: 460
Report this Post10-23-2021 12:55 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
In my case, it was a bad socket (or at least the contact in the socket.)
Be careful.. you can find the (supposedly) exact replacement socket on Amazon or eBay, but it will come with much smaller wires. Will probably burn out (or burn up) in short order.
I ended up stealing a socket and the associated wires from an old harness.
buddycraigg
Total ratings: 478
Report this Post10-23-2021 11:12 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes there is one.
I would check the relay.
72and86
Report this Post10-24-2021 10:37 AM Click Here to See the Profile for 72and86Send a Private Message to 72and86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
[QUOTE]Originally posted by theogre:
[/QUOTE]
What kind and where's this "socket"?
72and86
Report this Post10-24-2021 10:39 AM Click Here to See the Profile for 72and86Send a Private Message to 72and86Edit/Delete MessageReply w/QuoteDirect Link to This Post
72and86
Member since Aug 2016
Yes there is one.
OK. Located where?
Total ratings: 460
Report this Post10-24-2021 12:04 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are two of them, IIRC. They're in the front compartment, near the washer fluid reservoir. (The relays look just like the fuel pump and A/C relays that are in the back.)
I think that one is for the washer pump (that one is easy to identify, since the pump is right there) and the other is for the high speed fan setting.
Look for the socket with the large red and purple wires. One of those, on my car, is the one that had the compromised connector.
[This message has been edited by Raydar (edited 10-24-2021).]
