  Not quite complete L32 swap
Not quite complete L32 swap by TurboGN
Started on: 10-06-2021 12:58 PM
Replies: 4 (446 views)
Last post by: TurboGN on 10-09-2021 05:57 PM
TurboGN
Report this Post10-06-2021 12:58 PM Click Here to See the Profile for TurboGNSend a Private Message to TurboGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
I purchased a 1988 Fiero GT with a 3800 SC swap that's not quite complete. The hoses for A/C go all the way back into the engine compartment but are cut off. The compressor on the L32 doesn't look like it has any fittings to attach to and there is no harness connector for the sensor at the front of the compressor. The other missing piece of the harness is the connection to the oil pressure sensor. Where could I get the parts to finish this swap?
Total ratings: 200
Report this Post10-08-2021 10:39 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Honestly, I'd hit the junkyard and see what parts were on the original car it came from (Grand Prix?)... and then buy what you're missing or need so you can adapt it to the Fiero condensor, etc.
TurboGN
Report this Post10-08-2021 11:17 PM Click Here to See the Profile for TurboGNSend a Private Message to TurboGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you.
Report this Post10-09-2021 02:19 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I brazed on the 10mm switch port on the high side line near the firewall bulkhead and used the Fiero A/C OEM hose ends with new barrier hoses on them.
TurboGN
Report this Post10-09-2021 05:57 PM Click Here to See the Profile for TurboGNSend a Private Message to TurboGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you
