  Wires in radio area...
Wires in radio area... by CSM842M4
Started on: 10-05-2021 04:32 PM
Replies: 7 (278 views)
Last post by: IMSA GT on 03-17-2022 09:29 PM
CSM842M4
Report this Post10-05-2021 04:32 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Started putting the fresh center console parts in my wife's '84 (thanks, handymanpat!) and noticed something that made me concerned. There's a wire in one of the harnesses that has burned way back into the harness. I can't find anything in my Chilton's identifying radio wires (or the heat/ac wires), showing how far back I may have to chase this. To help eliminate what it ISN'T, it isn't in the heat/ac or fan speed switch harnesses, and it's not in the 4-wire 16 gauge (light blue, dark blue, brown, yellow) bundle (need to know what these do; rear/headrest speakers, maybe?). The wire in question is in the 7-wire 16 gauge bundle (light green, dark green, tan, grey, black, yellow and the burned one with a light-colored jacket). This car came to us with a poorly installed aftermarket stereo, and it has been troublesome at best. Can anybody help me identify the purpose of this wire and where it goes once it hits the main harness? Thanks in advance - Chris
CSM842M4
Report this Post10-05-2021 04:44 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
May have just stumbled on the answer... two grey wires in that particular bundle. One is a front speaker negative, the other comes out of either the headlight switch or the dimmer wheel. My bet is it's the illumination wire that shorted to ground...
CSM842M4
Report this Post10-05-2021 05:01 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
CSM842M4
Member since Mar 2016
BTW, still curious if anybody knows or remembers whether that wire goes to the headlight switch or the dimmer...
buddycraigg
Total ratings: 478
Report this Post10-08-2021 08:34 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am pretty sure it is from the headlight switch. It tells the radio to go in to "dim" mode when you have the lights on.
Can you post pictures?
CSM842M4
Report this Post03-16-2022 06:11 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, buddycraigg. You are correct, it's actually the grey wire out of the dimmer connector. While this thread is awake again, does anybody know for sure the functions of the wires at the dimmer? Pretty sure there's going to power from headlight switch, variable output to instrument lights, the radio output and possibly a full-on dome light power, but Chilton's wiring diagrams are so basic and patchy.
IMSA GT
Total ratings: 250
Report this Post03-17-2022 07:54 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
My question is, is the radio working correctly or are you blowing fuses?
CSM842M4
Report this Post03-17-2022 08:17 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, IMSA GT. Your question about the radio working comes with a long answer - the radio in the car when we bought it was a poorly installed aftermarket unit, but it did as it was supposed to. The factory unit in our third Fiero was obviously pulled out in favor of an aftermarket, but thrown back in when the prior owner put it up for sale (the mounting brackets are missing). So, the '84 SE is without factory connectors to hook up to the factory unit. However, to the best of my memory, we were not blowing fuses with the Sony stereo in the '84. I'm thinking of running a duplicate 16 ga. grey wire from the dimmer to the radio cavity, re-installing factory-style connectors, then either installing the Delco radio or using a proper wiring adapter for a Kenwood or Alpine unit.
IMSA GT
Total ratings: 250
Report this Post03-17-2022 09:29 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sometimes that grey wire creates major issues. The most common is that you turn on your headlights which activates the dimmer. The fuse blows which controls the down motion of the headlights as well as all of this:
So if you hook up the grey wire and the above list suddenly stops working once you try to raise the headlights, you'll know to disconnect the grey wire.
[This message has been edited by IMSA GT (edited 03-17-2022).]
