Update System
  1984 Headlight question...
1984 Headlight question... by David Riedle
Started on: 09-09-2021 07:09 PM
Replies: 9 (543 views)
Last post by: buddycraigg on 09-25-2021 08:32 PM
David Riedle
Report this Post09-09-2021 07:09 PM Click Here to See the Profile for David RiedleSend a Private Message to David RiedleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 14,000 mile Indy that is having an odd headlight issue. I have rebuilt both motors due to the disintegration of the gear and bumpers in my passenger side motor.
I replaced the gears and bumpers in both motors with aluminum gears and delrin bumpers, and the motors work well.
The issue that I am having is that my passenger side headlight will sometimes not go up. Turning the manual knob 10 degrees always makes the headlight go up. What is strange is that the headlight won't go up when the car is in the garage. When I drive the car on the road for a mile, it usually will work, and if it won't go up when I am driving, it will usually go up if I try it immediately. The grounds seem tight, and when I replaced the gears, the motors were like new inside, with the exception of the gears and bumpers.
Could I have a relay issue?
Report this Post09-10-2021 05:47 PM Click Here to See the Profile for Dennis LaGruaClick Here to Email Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the problem is confined to one motor then its likely the headlight relay or an internal motor problem. First check the relay. If OK, how are the brushes on the motor? Do they look solid or well worn? If they are well worn they may not always make a good connection to the motor armature.
FIREBOX
Report this Post09-21-2021 02:10 PM Click Here to See the Profile for FIREBOXClick Here to Email FIREBOXSend a Private Message to FIREBOXEdit/Delete MessageReply w/QuoteDirect Link to This Post
motor contact issue likely since turning motor shaft "slightly" starts it. Try just tapping the manual knob to get it running.
Report this Post09-22-2021 11:30 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageClick Here to Email fierofoolSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
That would indicate that the limiter switch point set failed to open at the end of travel. The bump opens them, allowing the opposite set of points to close and power the motor in the opposite direction of last travel. Power is still being applied until the point set is opened. No power is applied to the opposite until the light switch is activated to complete the circuit for that direction of travel.
In the dash switch, there are two circuits. One closes when the switch is turned on. That powers one side of the motor relay to raise the headlight. Power continues to be applied to that circuit, but the point set for UP should open at the end of travel, hence the circuit is now OPEN.
At this point, the point set for the DOWN movement is closed, but there is no power applied to that circuit until the dash switch is turned OFF. That completes the circuit and at the same time disconnects power to the UP circuit. At the end of travel in the DOWN movement, that pointset opens. Anywhere between fully open and fully closed, both point sets in the limiter switch are closed. There's just one side that is energized, dependin upon the position of the dash switch.
Total ratings: 570
Report this Post09-22-2021 05:41 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
metal gear is likely ok...
Delrin bumper will cause problems.
If are pushing Delrin and anything hard as bumpers in Gen1 motors... will break something that weaker same as covered in this thread for Gen2 HL motors:
https://www.fiero.nl/forum/Forum2/HTML/128600.html
GM made the bumper "soft" so motor shaft can safely hit End of Travel or jams and softer then everything else.
Plus keeping a load in the bumpers @ EoT make limit switches to stay off even if motor shaft tries to back off for vibration or sit for months.
Report this Post09-22-2021 06:35 PM Click Here to See the Profile for Dennis LaGruaClick Here to Email Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Must agree here. The impact softening and load storing effect of the internal rubber gear inserts is critical. It provides the shock absorbing function at the end of travel. This keeps the gear from being stripped out. If you use the Fiero Store repair kit for the Gen 1 motors it contains soft rubber inserts. The Delrins are usually provided in the Gen 2 repair kits. They are hard and do not cushion. While this repair can work for a while, I do not like them. I just replace the entire motors with new ones. They are $50 ea on eBay.
Total ratings: 570
Report this Post09-22-2021 06:41 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seen and Bought New Gen2 motors. But Not Gen1 motors...
David Riedle
Report this Post09-22-2021 07:10 PM Click Here to See the Profile for David RiedleSend a Private Message to David RiedleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wondered about the delrin "bumpers". I wondered if there was not enough give to the bumpers based on the tiny amount I had to move the knob. I think I should replace the relay, since this is the motor that did not shut off. Are just the bumpers available?
Report this Post09-22-2021 09:33 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageClick Here to Email fierofoolSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Swap relays between motors and see if the problem goes with the relay.
I think Rodney sells a viton rubber bumpstop set.
buddycraigg
Total ratings: 478
Report this Post09-25-2021 08:32 PM Click Here to See the Profile for buddycraiggClick Here to Email buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
The problem is in the motor most likely.
I guess the contact in the isolation relay could be bad for that side. I would really suspect the motor though.
You can try this without taking the motor completely apart.
Take out the limit switch.
then stick a scotchbrite pad in there where the commutator is and turn the motor by hand a few times.
Then some fine sandpaper to clean up the contacts.
Put it back together and see if it is better.
[This message has been edited by buddycraigg (edited 09-26-2021).]
