HP does matter here but High RPM likely have problems....
Angle cut gear set is "quieter" but also stops cam run out. At high RPM that likely loads up the gear and thrust bearing way beyond spec.
Strait cut gear set may help but may need to add parts to the cover to limit cam run out because OE "thrust bearing" can break if loaded from the back. The Bolts to mount the bearing mostly just holds it in place when used w/ angle cut gear.
Angle cut sets are/where most only available as OE phenolic or aluminum cam gear. Both uses Steel gear for crank.
Note: GM has a TSB to replace them "easier" but also update to oil the gear more.
1mm (.040 inch) drill bit thru a small plug behind the cam gear allow more oil spraying it w/o dropping oil pressure.
Plus "new" cam thrust/retaining part have holes to let more oil but that also no longer made.
See my Cave,
Cam GearsCaution:High pressure/flow oil pump or problems w/ pump, distributor or both will also put larger loads on the cam and timing set.
While the Aluminum gear set is "stronger" the OE, often only hinds those problems w/ stock and mod'ed Dukes w/ HEI.
High RPM also cause more load from the pump and dist and thus more load for the cam and gears to "eat."
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 08-31-2021).]
