  Where to find a prom for 7730 ECM
Where to find a prom for 7730 ECM by Gryffindad
Started on: 08-19-2021 10:40 AM
Replies: 14 (291 views)
Last post by: fierofool on 08-22-2021 08:57 PM
Gryffindad
Report this Post08-19-2021 10:40 AM Click Here to See the Profile for GryffindadSend a Private Message to GryffindadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys,
I'm putting Jcirc's old turbocharged 3.4l in my Fiero and picked up a 7730 ECM (the engine was already wired for it) but I need to find a prom.
Anyone know where I can get one or the part number to search for?
Thanks
Total ratings: 328
Report this Post08-19-2021 07:49 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
We installed that 3.4L engine in Jerrys Fiero before he went turbo. I knew the previous owner of that engine before he sold it to Jerry. Later he went to performance shop and they installed the turbo kit and changed the ECM and I don't know what those guys did.
I believe the 7730 ECM used a 27C512 eprom that can be replaced with a flash memory chip 27SF512. Those part numbers are blank un-programmed memory chips. You would then need to program that chip starting with say a code from a 4.3L GMC turbo Cyclone and then tweak the program for your engine.Point is putting in a specifically programmed chip for that engine is what is needed.
Gryffindad
Report this Post08-19-2021 08:27 PM Click Here to See the Profile for GryffindadSend a Private Message to GryffindadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, glad someone is around from then! I appreciate the reply here. I've looked at as many of Jcirc's old threads on it as I could to get information on the engine and setup, I'm not a mechanic though I have a local shop working on it.
What I have is the 3.4L from Jcirc and the Remera from Txopie, the engine and transmission are in, new axle is on, and I grabbed 7730 pictured below. My shop has a programming guy who will be working on it, they've just been having me supply the parts though so I'm trying to figure out what I need exactly.
So it sounds like the 27SF512 chip will go in the ECM pictured below, then start with the 4.3L GMC Turbo Cyclone
Total ratings: 328
Report this Post08-20-2021 03:38 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's correct but if your shop starts with the Turbo cyclone program, have them make sure that the engine has a 2 BAR MAP sensor that senses vacuum and boost. The standard Fiero MAP sensor does not. The 7730 also uses a knock sensor and you will need the sensor and the ESC module that is essentially an A/D converter box. The sensor connects to the ESC module and the that goes to a pin on the ECM.
jdv
Report this Post08-21-2021 07:05 PM Click Here to See the Profile for jdvSend a Private Message to jdvEdit/Delete MessageReply w/QuoteDirect Link to This Post
RacerX11
Report this Post08-21-2021 11:15 PM Click Here to See the Profile for RacerX11Send a Private Message to RacerX11Edit/Delete MessageReply w/QuoteDirect Link to This Post
You need an entire memcal, not just the eprom chip.
Total ratings: 328
Report this Post08-22-2021 07:52 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correct. Neglected to mention that but the Moates adapter allows you to use a reprogrammed eprom chip. Trying to erase and reprogram it while on the memcal is not the best way to do it.
Here it is with a zif socket that makes removal and insertion easy
[This message has been edited by Dennis LaGrua (edited 08-22-2021).]
Total ratings: 260
Report this Post08-22-2021 08:32 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you tear apart an old ecm for the memcal connector, then you can add some spider legs to it that allows mounting the memcal base to the programmer and eliminates the need to remove the eprom chip every time you need to make a tune change. You do have to remove the stock eprom and install a flash erase version first.
Total ratings: 461
Report this Post08-22-2021 11:34 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry to be a "stick-in-the-mud".
Tunercat shows that a 7730 uses a 27C256. Not a 512. (Can a 512 be used in place of a 256?)
...then start with the 4.3L GMC Turbo Cyclone
The Syclone/Typhoon used a 7749 ECM and a 27C128 chip.
I have no idea about cross-compatibility of any of these pieces. But I wouldn't count on it.
All this info comes from http://www.tunercat.com/ under "ECM Definition Files".
Edit - I did find "$8F 1227727 89 - 90 Buick / Pontiac LG5 3.1L V6 MFI Turbo 27C256"
2nd Edit - It also appears that some cars used a 7727 and a 7730 interchangeably, using the same (different) code mask. So the $8F mask above may be able to be used in your 7730.
[This message has been edited by Raydar (edited 08-22-2021).]
Total ratings: 154
Report this Post08-22-2021 02:24 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Adding to what Dennis said about the knock sensor. Sinister Performance told me to use a knock sensor for the vehicle the 7730 ECM came from. In my case, a 91 Beretta 3.1. That's the knock sensor I purchased.
Total ratings: 328
Report this Post08-22-2021 02:57 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
by RAYDAR
Thanks for the clarification and the correction. We would not want to give out bad info. With reference to the Cyclone/Typhoon program; it is set up to manage boost and that is why I thought it may be a good starting point. To my knowledge the 7730 was not set up that way. It would require moving the main timing table over by a factor of two and splitting it for boost and vacuum readings. It can be done but the software to do it may not be readily available. Looking back at this the 7749 ECM and modifying that program may be the better choice but program compatibility needs to be explored. I use the turbo program for the 85 Fiero V6 ECM w knock sensor and that's another alternative.
RacerX11
Report this Post08-22-2021 03:29 PM Click Here to See the Profile for RacerX11Send a Private Message to RacerX11Edit/Delete MessageReply w/QuoteDirect Link to This Post
To work properly, knock sensors are tuned to a specific frequency which is dependent on the bore size of the engine. For the 92mm bore of the 3.4 engine you would want to use a knock sensor from a 93-95 Camaro V6. The 3.1 sensor would not be correct.
RacerX11
Report this Post08-22-2021 03:46 PM Click Here to See the Profile for RacerX11Send a Private Message to RacerX11Edit/Delete MessageReply w/QuoteDirect Link to This Post
RacerX11
Member since Feb 2003
The 7727 is just the underhood version of the 7730, with different connectors. $8F will run fine on the 7730.
RacerX11
Report this Post08-22-2021 03:50 PM Click Here to See the Profile for RacerX11Send a Private Message to RacerX11Edit/Delete MessageReply w/QuoteDirect Link to This Post
RacerX11
Originally posted by Dennis LaGrua:The 7730 also uses a knock sensor and you will need the sensor and the ESC module that is essentially an A/D converter box. The sensor connects to the ESC module and the that goes to a pin on the ECM.
The knock circuit for the 7730 is built into the memcal, so no ESC module needed. The knock sensor wires direct to the ECU.
Total ratings: 154
Report this Post08-22-2021 08:57 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you. Before I get mine installed, I'll question Ryan again to be sure I understood him correctly.
