  formula stalls when warmed up and under load
formula stalls when warmed up and under load by england006
Started on: 07-26-2021 08:12 PM
Replies: 3 (93 views)
Last post by: Patrick on 07-26-2021 11:45 PM
england006
Report this Post07-26-2021 08:12 PM Click Here to See the Profile for england006Send a Private Message to england006Edit/Delete MessageReply w/QuoteDirect Link to This Post
runs fine when cold. when warmed up and starting, it stalls when putting into gear. once cooled down its fine again
could it be the TCC connector? why would this not be a problem when cold?
Xenoblast
Report this Post07-26-2021 08:56 PM Click Here to See the Profile for XenoblastSend a Private Message to XenoblastEdit/Delete MessageReply w/QuoteDirect Link to This Post
in some cars i think, the torque converter does not lock up when cold. Im not sure if the fiero does this, but if so, it could be ignoring the TCC signal until it gets warm, and when it does it is telling the car to lock up always.
england006
Report this Post07-26-2021 11:10 PM Click Here to See the Profile for england006Send a Private Message to england006Edit/Delete MessageReply w/QuoteDirect Link to This Post
it also stalled out when warmed up and going into reverse. Could the TCC even be engaged in reverse?
Total ratings: 458
Report this Post07-26-2021 11:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seems to me the simplest thing to do to rule out the TCC is to unplug it and see what happens!
