  Odometer stopped working: Trip Odometer and Speedometer work
Odometer stopped working: Trip Odometer and Speedometer work by reinhart
Started on: 07-15-2021 10:10 AM
Replies: 7 (323 views)
Last post by: theogre on 07-17-2021 06:55 PM
reinhart
Report this Post07-15-2021 10:10 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
88GT:
So my odometer stopped turning but my trip odometer, tach, and speedometer work fine.
Does this eliminate any wiring or connector issues outside the instrument pod? Does this mean it's an odometer motor that went bad? Or what else could cause this?
And is there any way to test the odometer with the cluster out of the car? e.g. Can I hook up voltage to a couple posts and get the odometer to turn without it installed in the car or do I need a functional VSS signal?
Report this Post07-15-2021 04:52 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can be several things...
motor or speedo board bad.
dirt in odo
broken odo counter
see https://www.fiero.nl/forum/.../HTML/145251.html#p1
reinhart
Report this Post07-15-2021 06:01 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
dirt in odo
broken odo counter
From the other thread:
2 drive 2 stepper motors for odo and trip
Your problems is #2.
The board or oddo motor might be bad.
The counter might be bad.
"Easy" way to look...
You have to pull the gauge front trim and "glass" and have a camera to watch the odo when you drive"
What am I looking for with the camera to give me an indication whether its the board, motor or counter?
reinhart
Report this Post07-15-2021 06:26 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
reinhart
Member since Mar 2002
And can I bench test with it removed? Seems like that would be easiest as pulling the front face requires removing the instrument pod and then remounting it.
Report this Post07-16-2021 08:57 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
The gear will move when driven.
Can bench it but faster just "watch" while driving.
Front trim is easy to remove. Gauges have own screws hold them in.
plus can often see if just "dirt" trapped in the gear at right side of counter.
Better to remove front and bottom trim to remove the speedo anyway. Save messing w/ entire dash and steering column and breaking other parts.
If trip odo works then Not a board problem.
Just look at a spare and both motors are wire in parallel to same 2 driver chip pins.
But think motors may spins opposite because plug is wired + - - + (or - ++ - ) If the motors care about polarity.
motors are covered in US patent 3495113A 3469132A and don't have time to read.
[This message has been edited by theogre (edited 07-16-2021).]
J Gunsett
Report this Post07-16-2021 01:59 PM Click Here to See the Profile for J GunsettClick Here to visit J Gunsett's HomePageSend a Private Message to J GunsettEdit/Delete MessageReply w/QuoteDirect Link to This Post
The trip, odometer and speedo all work from the same signal. If 2 are working the servo motor has stopped working for the trip odometer. You have a PM.
Jack
HarryT
Report this Post07-17-2021 02:41 AM Click Here to See the Profile for HarryTSend a Private Message to HarryTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had that problem and was advised to wiggle and push the odometer reset button while driving. It fixed the problem. Try it, sometime the problem is an easy fix.
HarryT
Report this Post07-17-2021 06:55 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
That should only affect the trip odo.
When you push the Reset Button on the Trip Odo, you must push and release slowly and if needed push 2 or more times to see all 0's inline.
Trip Odo can get stuck, even damage it, if resetting fails.
GM has several TSB just saying same for Fiero and some other models.
Dirty Main Odo gears can cause same problems.
Motor tries to turn but jam gear(s) won't move or can break.
Odo Counters are easy to break because has small plastic parts.
Trip have some more parts you see easy because of reset function but main odo works the same plus has "anti-tamper" parts to prevent people "rolling back" the odo for sale of car.
