What is the torque spec for a 1987 auto trans case to case bolts?
There are 21 bolts in total. Some are hex hed and some are torx head. I split the cases to refresh and finding these torque specs are the only thing holding me back from finishing it.
There are three sprocket support bolts. One goes through the valve body and separator plate. Two are external. one is at about 12:00, the other at about 4:00. They could weep fluid from under the bolt heads. Put sealer on the threads of the case bolts that have open holes to the inside of the bellhousing. They could weep and be misdiagnosed as a converter seal leak. Don't forget the small accumulator gasket in the center. Hope this helps,
