  Fuel Pump High Performance Upgrade?
Fuel Pump High Performance Upgrade? by reinhart
Started on: 07-05-2021 09:27 PM
Replies: 7 (331 views)
Last post by: DimeMachine on 07-08-2021 10:25 PM
reinhart
Report this Post07-05-2021 09:27 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was looking through fuel pump applications on Rock Auto and I'm a bit confused. I found the following:
Using Delphi Pumps across the board:
Fiero V6 = FE0039: GP = 26, max pressure=87, PSI=50
https://www.rockauto.com/en...9208&pt=6256&jsn=607
87-91 Sunbird L4 Turbo = FE0113: GP = 20, max pressure=71, PSI=44
https://www.rockauto.com/en...0852&pt=6256&jsn=671
89 Trans Am V6 Turbo = FE0110: GP = 22, max pressure=70, PSI=44
https://www.rockauto.com/en...1571&pt=6256&jsn=549
1) So what am I missing here? Why is a Fiero fuel pump higher rated than a trans am turbo?
2) Why are the Sunbird Turbo (2.0L) and Trans Am Turbo (3.1L) nearly the same?
3) What pump are people that are turboing their stock 2.8L going to or is there even a need if the stock Fiero pump flows more than a stock Trans Am turbo pump?
Blacktree
Total ratings: 350
Report this Post07-06-2021 07:40 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
It would appear the Delphi FE0039 is a little overkill for the application. Not sure why it's spec'd for that. But it should be good for about 220 HP, on a turbocharged engine. If you need more than that, the Delphi FE0114 also fits in the Fiero sender unit. And it's rated for 35 GPH (good for about 300 HP in your application). You'll have to trim the rubber pad under the pump a little, to make it fit.
Here's a link: https://www.jegs.com/i/Delphi/117/FE0114/10002/-1
[This message has been edited by Blacktree (edited 07-06-2021).]
pmbrunelle
Total ratings: 62
Report this Post07-06-2021 09:18 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed the EP381 pump (it dropped in without mods) in my Fiero, and it's been working fine with a turboed stock V6. Stock regulator and fuel lines as well.
It is suggested to perform the hot-wire mod, so that your new pump is supplied with full voltage:
http://www.gmtuners.com/fiero/hot_wire.htm
[This message has been edited by pmbrunelle (edited 07-06-2021).]
reinhart
Report this Post07-07-2021 04:34 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is it a Delphi issue? I was just using Delphi because the other GM pumps weren't available to compare. So the stock GM pump for the V6 Fiero is a much lower capacity than the V6 3.1 GM pump?
What pump are 3.8SC guys using?
reinhart
Report this Post07-07-2021 04:43 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
reinhart
Member since Mar 2002
I found the Delphi FE0114. It's rated at 32 GP
https://www.rockauto.com/en...4439&pt=6256&jsn=443
What are the GP flow numbers for the stock GM V6 and how much HP can it handle?
hnthomps
Total ratings: 50
Report this Post07-07-2021 11:01 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
DeatschWerks 200 0r 300 for 3800 SC engines.
Nelson
reinhart
Report this Post07-08-2021 02:35 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nelson
Couldn't find anything from them on RockAuto. What are the GP #s for those two? And what's the HP rating?
DimeMachine
Report this Post07-08-2021 10:25 PM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nelson
I couldn't agree more - especially if you are going to use E85!
