  407 HP
407 HP by Frenchrafe
Started on: 06-11-2021 11:05 AM
Replies: 23 (566 views)
Last post by: Frenchrafe on 06-21-2021 06:17 PM
Frenchrafe
Report this Post06-11-2021 11:05 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
'Nuff said !
Bonne journée.
Link to video:
https://youtu.be/M6URzFspngg
"Turbo Slug" - '87 Fiero GT. 3800 turbo. - The fastest Fiero in France!
https://www.youtube.com/cha...1wZvWQlkYxTjivW_0XNg
[This message has been edited by Frenchrafe (edited 06-14-2021).]
Blacktree
Total ratings: 350
Report this Post06-11-2021 11:47 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a nice torque curve! For us Americans, 491 Nm is about 362 ft-lb.
fishsticks
Report this Post06-11-2021 12:07 PM Click Here to See the Profile for fishsticksSend a Private Message to fishsticksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look at that. 3500 RPM range within 10% of peak torque.
Yeah, that thing's a monster exiting a turn...
Frenchrafe
Report this Post06-11-2021 12:11 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, we tuned it to give max torque.
On 1 dyno pull, we got 447HP but it was too lean!
Backed off a bit, and tried to go for a nice linear power curve.
I am pleased with the result 👍👌😀
Frenchrafe
Report this Post06-11-2021 12:16 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Frenchrafe
Member since Feb 2017
And yes, Turbo Slug is unbeatable coming out of a turn !
[This message has been edited by Frenchrafe (edited 06-11-2021).]
Notorio
Report this Post06-11-2021 01:01 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is physically happening at around 6200 rpm that causes HP and TRQ to drop like a rock? Are the valves no longer able to seal?
Frenchrafe
Report this Post06-11-2021 01:14 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Probably being over cautious on the dyno.
Anyway, there's a 6500rpm cutout in the tune.
The dyno guy knew this and lifted his foot before. In his experience, he doesn't push an engine to it's absolute limit.
He (and I) wanted max perf and reliability😉
Notorio
Report this Post06-11-2021 11:18 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, got it. Just curious how much boost you are running and how that would compare to the boost in the SC version. I guess that will be Apples vs Oranges no matter how you think about the two.
La fiera
Report this Post06-12-2021 12:02 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome Rafe!!
Frenchrafe
Report this Post06-12-2021 12:39 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't run alot of boost ; between 0.75 and 1 bar. Yesterday, we were just running at wastegate spring pressure. So more in the 0.75bar range (11 psi ?).
It was mighty hot yesterday as well and I saw a 40°C intake temp. My intercooler works better on the track/road than on the dyno! Not enough airflow even with dyno fans.
Frenchrafe
Report this Post06-12-2021 12:40 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Frenchrafe
Originally posted by La fiera:
Awesome Rafe!!
Thanks Rei👍😉
fishsticks
Report this Post06-12-2021 01:23 PM Click Here to See the Profile for fishsticksSend a Private Message to fishsticksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your IC is just in front of the engine with a spoiler directing air upwards, correct?
Maybe put together some flexible ducting and get some dyno air under there next time?
Frenchrafe
Report this Post06-13-2021 04:05 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's exactly what the dyno opperator said!
He suggested extra tubing in my engine bay as well to duct cold air towards the turbo. He thought it was mighty tight and hot in there.
Frenchrafe
Report this Post06-13-2021 04:10 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Frenchrafe
A few of photos of the dyno day :
Trinten
Report this Post06-14-2021 10:22 AM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
C'est manifique! Vous avez pris soin de votre voiture. Ca a l'air bien!
(that is the most French I've used since I took classes in high school... hopefully it made sense).
[This message has been edited by Trinten (edited 06-14-2021).]
Frenchrafe
Report this Post06-14-2021 12:28 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Merci.
Tu maîtrises bien la langue française 👍😉
Total ratings: 236
Report this Post06-14-2021 01:02 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
So far zero pics of the turbo engine... Looks like a 3800 from your YouTube vid?
Frenchrafe
Report this Post06-14-2021 03:00 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's not a pretty engine to look at from the top, and yes it's a 3800 S2.
Next time I drop the cradle, I'll try to remember to take some photos !
Here's a photo from last year:
Otherwise, check out the build vid for lots of engine photos :
https://youtu.be/zFp07WovKXk
Total ratings: 236
Report this Post06-15-2021 07:55 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
So what if it's not "pretty"? You built it. Own it!
Frenchrafe
Report this Post06-15-2021 07:59 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post06-15-2021 10:16 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Torque is king - always tune for maximum torque.
Great results!
Total ratings: 236
Report this Post06-19-2021 09:50 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's literally what tuning is
PK
Report this Post06-21-2021 10:56 AM Click Here to See the Profile for PKSend a Private Message to PKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Trays beans rafe. Even sourcing les parts must have been a mission!
My work ve-hickle is also called "slug" but that's only 67hp....sorry no Dyno to prove!
Frenchrafe
Report this Post06-21-2021 06:17 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some body parts yes. The latest PCM was helped out by a fellow forum member.
But most current parts are Rock Auto or Fiero Store.
Hey, don't need a dyno to know when it's a Slug!😜 That comes from feeling and driving reactions!
Cheers,
Rafe
