  2.5 Wont Idle When AIR is hot. (or something idk)
2.5 Wont Idle When AIR is hot. (or something idk) by gb.84.fier0
Started on: 06-09-2021 02:43 PM
Replies: 4 (242 views)
Last post by: gb.84.fier0 on 06-18-2021 10:06 PM
gb.84.fier0
Report this Post06-09-2021 02:43 PM Click Here to See the Profile for gb.84.fier0Send a Private Message to gb.84.fier0Edit/Delete MessageReply w/QuoteDirect Link to This Post
My 2.5 auto that sat for 20 years, will not idle when the outside air is hot. So on a 60 degree day, you can start it and drive it for a hour no problem. But as soon as you shut it off and then turn it back on, it cannot idle. Already replaced MAP sensor, fuel pump, and other stuff too. In the cold air and if its the first time you ran it that day, it idles just fine. Could it be a vacuum leak?
Car has 88,000 miles
84 stock :(
Report this Post06-09-2021 11:31 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
try See my Cave, ECM Heat
If that helps, vary likely ECM need replacement. Save the PROM to go into new ECM.
Otherwise can be a lot of things getting hot.
gb.84.fier0
Report this Post06-17-2021 02:15 PM Click Here to See the Profile for gb.84.fier0Send a Private Message to gb.84.fier0Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I replaced the iac, and now it idles wayy to high, like 2000 rpm. There are instructions on how to reset the iac. Do I do that?
84 stock :(
Report this Post06-17-2021 11:00 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
No.
If you haven't drive it,,, ECM will reset that when drive > 35mph for a few minutes.
gb.84.fier0
Report this Post06-18-2021 10:06 PM Click Here to See the Profile for gb.84.fier0Send a Private Message to gb.84.fier0Edit/Delete MessageReply w/QuoteDirect Link to This Post
I can't even put it into drive without hurting my trans the idle is so high, do I just manually adjust the iac so it can drive and let the ecm do the rest of the work?
84 stock :(
