  Smelling hot rubber after drive
Smelling hot rubber after drive by Squall86GT
Started on: 06-08-2021 08:10 PM
Replies: 14 (323 views)
Last post by: cvxjet on 06-18-2021 01:48 PM
Squall86GT
Report this Post06-08-2021 08:10 PM Click Here to See the Profile for Squall86GTSend a Private Message to Squall86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
After a 10 minute drive or so, it seems like each time there’s kind of this hot smell of rubber in the garage. My best guess would be a belt. What’s a good way to see if the belt is too tight? Or should I look at something else?
It’s got new brakes if that matters. Thanks
Report this Post06-08-2021 08:44 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
After a drive, touch every brake disc with the back of a knuckle to see if one or more are hotter than the rest.
Mike in Sydney
Report this Post06-08-2021 08:57 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep. Sounds like a dragging pad.
Squall86GT
Report this Post06-08-2021 09:08 PM Click Here to See the Profile for Squall86GTSend a Private Message to Squall86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I’ve got a laser thermometer. I’ll try that. Thanks guys.
Report this Post06-08-2021 11:03 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where's your sense of adventure? The back of my knuckles aren't scarred all that badly. lol
Skybax
Total ratings: 78
Report this Post06-09-2021 09:26 AM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
When "driving normal" in summer weather...
- After a short drive the calipers should be approximately 90-110 degrees
- After a longer drive the calipers should read approximately 125-150 degrees
- The fronts should be slightly hotter than the rear
If any one caliper is much higher than the other three there is an issue.
Skybax
Total ratings: 78
Report this Post06-09-2021 09:27 AM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Skybax
Member since Jun 2003
Another thing you want to check and make sure a plastic baggie is not stuck/melting on exhaust that you might have picked up on the roadway.
Report this Post06-09-2021 02:34 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Skybax:
After a short drive the calipers should be approximately 90-110 degrees...
Calipers? I suspect you meant the rotor/brake discs.
[This message has been edited by Patrick (edited 06-09-2021).]
OldsFiero
Report this Post06-10-2021 08:58 PM Click Here to See the Profile for OldsFieroSend a Private Message to OldsFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many of my customers described oil leaking on hot exhaust parts as a burning rubber smell. Might be worth a look. It may avoid the " they all catch fire " syndrome.
Marc
Squall86GT
Report this Post06-11-2021 12:11 PM Click Here to See the Profile for Squall86GTSend a Private Message to Squall86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I drove about 2 miles. It’s a very warm humid day here. The rotors in the back we’re both about the same at like 123°F in the front two were like 126.
I did notice a small oil spot before driving it sort of towards the front of the engine which is basically lined up with the front side of the rear tires. Possible that that oil is getting on exhaust pipes up there?
Thanks guys
Report this Post06-11-2021 12:15 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rotors Pads and some others will get hot and can Burn you easy.
When using IR etc to read them...
read both Fronts then Both rears and quickly.
Fronts should be very close to each other. Same for rears. Often Won't see same for all and is normal.
Quick because rotors and more cool faster then most think and reading temp won't matter if you wait too long to read.
Pad Dragging can be one to several problems...
Piston problems, slider problems, etc.
See my Cave, Brake Service and rest of section.
Squall86GT
Report this Post06-17-2021 11:58 PM Click Here to See the Profile for Squall86GTSend a Private Message to Squall86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don’t know what it was. I’ve driven it a few more times and it’s not very pronounced now
steve308
Total ratings: 58
Report this Post06-18-2021 08:08 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
If a v6 check for oil leak around the distributor.
Skybax
Total ratings: 78
Report this Post06-18-2021 10:21 AM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Normal.
cvxjet
Report this Post06-18-2021 01:48 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
The front valve cover area can leak oil which drips on exhaust manifold; Usually just smell, but can catch fire. When cool, use mirror & light and look baclk there, the take paper towel and feel around- see if any wet oil.
