  Should an unplugged EGR throw a code?
Should an unplugged EGR throw a code? by tnkgnr
Started on: 04-29-2021 11:55 PM
Replies: 3 (404 views)
Last post by: tnkgnr on 04-30-2021 11:12 PM
tnkgnr
Report this Post04-29-2021 11:55 PM Click Here to See the Profile for tnkgnrSend a Private Message to tnkgnrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just curious - I took apart my EGR solenoid and saw it was rusted tight and would not operate. The car never threw a code 32 like this. Also, I've disconnected the electrical connector and there is no code 32.
Is this normal?
Report this Post04-30-2021 09:34 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Assuming MIL light works and ECM doesn't have a "Performance/Custom Chip..."
Should pop a code but depending where/how you drive may not show easy or often.
ECM doesn't trip several codes unless meet X error over Y time so driving in city maybe harder to trip then driving anywhere that keeps speed higher then 35mph or more for 10 minutes to half hour.
If ECM command X function, "timer" starts counting, if you stop or slow down and ECM disables/ignores X then counter is reset for next use of X.
24 VSS fail is one like that too. You unplug VSS and error may trip at "random" distance/time miles away w/o ECM reading speed. Plus even then the check engine light often only blinks, not on forever or even a few minutes.
44 lean and 45 rich is often same way.
Even Weather can affect tripping these two because often involves MAT/ACT sensor.
Example: Read MAT in my Cave, DIS Ignition
Report this Post04-30-2021 12:56 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the Check Engine Soon light come on with the ignition in the ON position? Might be the bulb has been removed or burned out?
tnkgnr
Report this Post04-30-2021 11:12 PM Click Here to See the Profile for tnkgnrSend a Private Message to tnkgnrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay, thanks. Yes, my check engine light operates and I don't believe there to be a performance chip in there.
