  Luck with Junkyard Automatic transmissions?
Luck with Junkyard Automatic transmissions? by Dennis LaGrua
Started on: 04-29-2021 03:41 PM
Replies: 3 (525 views)
Last post by: Dennis LaGrua on 04-29-2021 07:57 PM
Report this Post04-29-2021 03:41 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 4T60e on my 4.9L 85GT was D.O.A. and I ordered a remanufactured unit but it has yet to show up. A friend recommended that I cancel and go with a salvage yard unit that can be had for $200-$300. The remanufactured units are $1,600, a bit steep for my taste. Some cars end in in up a junkyard because of accident damage but others are there with blown engines and/or transmissions. Anyone here have any luck with junkyard automatic transmissions? The junkyards around here puncture the gas tanks and drain them so you can see them run.
cebix
Report this Post04-29-2021 04:28 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't know about USA but I've had luck with a THM125C from a local (yes) Grand Am for parts. When I changed the fluid on it, well it was looking very fresh and runs for some years now without problems. You never know though.
Report this Post04-29-2021 06:55 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think you answered your own question. Find a transmission that is still in the car.....and the car must be mashed up. Then you know the trans was good right to the end.
Report this Post04-29-2021 07:57 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
That obviously makes the most sense. I'm finding some decent deals on re-manufactured units but the 4T60e had more than a dozen different variations that had small changes as in the sprockets, final drive ratios and TC stall speeds. I guess the guy that I had set up to do the trans will get the nod.
