  Picked up some Subaru WRX wheels.
Picked up some Subaru WRX wheels. by Curlrup
Started on: 04-28-2021 06:08 AM
Replies: 14 (448 views)
Last post by: tnkgnr on 04-30-2021 11:16 PM
Curlrup
Report this Post04-28-2021 06:08 AM Click Here to See the Profile for CurlrupSend a Private Message to CurlrupEdit/Delete MessageReply w/QuoteDirect Link to This Post
From a 2003 WRX. Good deal too $150 for all 4 with new tires on them....guy is more bing and just needs them gone. I know the center bore needs to be enlarged 1 mm to 57.1. Anything else I should know or do? Never put one brand on another before.
Report this Post04-28-2021 02:06 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Curlrup:
From a 2003 WRX. I know the center bore needs to be enlarged 1 mm to 57.1
Any idea what that will cost to have done?
It's great that a lot of Subies have the same bolt pattern as Fieros, and the offset required is similar as well. It's too bad the center bore is a different size.
With aftermarket wheels that use hub centric rings though, it's just a matter of using different rings to then be able to swap the wheels between cars. I now have aftermarket wheels on my '98 JDM Impreza STi that I used to run on my Fiero(s).
[This message has been edited by Patrick (edited 04-28-2021).]
IXSLR8
Report this Post04-29-2021 01:02 AM Click Here to See the Profile for IXSLR8Send a Private Message to IXSLR8Edit/Delete MessageReply w/QuoteDirect Link to This Post
You might be able to use a router and bit with a bearing on the end to router out your center hole if its an aluminum rim.
Report this Post04-29-2021 01:17 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I highly doubt it would be possible to perfectly center a larger center bore hole using a router. Not something I'd want to attempt when its the center bore of the wheel that keeps it centered on the hub.
cam-a-lot
Total ratings: 97
Report this Post04-29-2021 05:09 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Please don't do this. The hole needs to be concentric. It needs to be done on a lathe while the wheel is turning to ensure the bore is concentric to the OD. Alternatively, a manual or CNC boring mill can enlargen the hole, as long as the exact center of the wheel is located and dialed in prior to machining and the wheel is securely clamped.
Total ratings: 236
Report this Post04-29-2021 09:33 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Going to use them with spacers? Get hub centric spacers with the correct pilot diameter.
Curlrup
Report this Post04-29-2021 01:24 PM Click Here to See the Profile for CurlrupSend a Private Message to CurlrupEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fly cutter on a Bridgeport. Easy peasy. I need to 3D print some center caps now. The hubs stuck out 1/4 inch. Rides great. I could have taken a little more out. They are tight but go on. Clearance Clarence.
[This message has been edited by Curlrup (edited 04-29-2021).]
Report this Post04-29-2021 01:33 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I expected to see gold colored wheels!
Curlrup
Report this Post04-29-2021 01:41 PM Click Here to See the Profile for CurlrupSend a Private Message to CurlrupEdit/Delete MessageReply w/QuoteDirect Link to This Post
These were silver. Previous owner plasti dipped them. I'm going to peel it and paint it...correctly. The dip is on for now, it works but if you get close it looks sloppy. No sir I don't like it.
Curlrup
Report this Post04-29-2021 01:46 PM Click Here to See the Profile for CurlrupSend a Private Message to CurlrupEdit/Delete MessageReply w/QuoteDirect Link to This Post
Curlrup
Member since Apr 2007
I think these are going to be like the wheels on my Honda Fit I had many moons ago. EVERY time a wheel had to come off I had to beat it off with a BFH they were that tight. Those were factory wheels. So I guess a question is if they are tight now, I'm assuming aluminum wheels on steel hubs will have some galvanic corrosion going on being made worse from a tight fit?
Report this Post04-29-2021 02:22 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm assuming aluminum wheels on steel hubs will have some galvanic corrosion going on...
With any wheels that fit snugly on the hub, I'll usually apply a little bit of antiseize where contact is made to allow for easier future removal of the wheels.
Curlrup
Report this Post04-29-2021 03:58 PM Click Here to See the Profile for CurlrupSend a Private Message to CurlrupEdit/Delete MessageReply w/QuoteDirect Link to This Post
In other news. Just curious. It was only 1 mm to take out. Split across the diameter that's .5 mm a side or 19 thousandths of an inch. Not much. I would think you could DIY this to some extent and keep it concentric. If you were off it would be a very small amount, and possibly within tolerance. Or not. If you had to remove anymore material no way you could DIY this.
tnkgnr
Report this Post04-30-2021 12:25 AM Click Here to See the Profile for tnkgnrSend a Private Message to tnkgnrEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what I have on mine as well. I look forward to seeing your 3d printed solution. I played around with it a little but didn't really like what I made.
Curlrup
Report this Post04-30-2021 09:55 AM Click Here to See the Profile for CurlrupSend a Private Message to CurlrupEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sweet! Looks good. Did you use spacers or bore out the center? Spacers scare me.
I found a file that was modified form doublec4's file. It's too big but I'm just messing around with scale in my slicer to see if I can dial it in some. I like the file its simple and has a Fiero logo on it. Once I get it dialed in I'll share some pics.
tnkgnr
Report this Post04-30-2021 11:16 PM Click Here to See the Profile for tnkgnrSend a Private Message to tnkgnrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fortunately I bought it like that - they were bored out.
