  Coolant Pipes Compatibility
Coolant Pipes Compatibility by cmd88
Started on: 04-17-2021 02:32 PM
Replies: 3 (339 views)
Last post by: Will on 05-04-2021 08:41 PM
cmd88
Report this Post04-17-2021 02:32 PM Click Here to See the Profile for cmd88Send a Private Message to cmd88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are Fiero coolant pipes the same for all models?
cmd88
AsaBergman
Report this Post04-17-2021 05:12 PM Click Here to See the Profile for AsaBergmanSend a Private Message to AsaBergmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
No. There's a difference between 2.5 and v6 pipes and then there's a change in design for the 88. As well the v6 has three pipes, the 2.5 has two.
The 88 pipes curve into the center of the car at the front end and bolt under the front subframe, the earlier pipes curve behind the wheel areas to the radiator.
Mickey_Moose
Total ratings: 145
Report this Post05-03-2021 03:05 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also if you throw the cross over pipe in there, they are different if manual or an automatic.
Total ratings: 237
Report this Post05-04-2021 08:41 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
cmd88
Does your username mean you have an '88?
I'm pretty sure the large coolant pipes are the same for 4 cyl or V6.
However, in '84-'86, the heater pipes had an independent circuit, with both ends connected to the engine. For '87 & '88, the heater return T'd into the right coolant pipe instead of returning to the engine.
So the '87 & '88 coolant pipes have the heater return connection near the rear of the right-side pipe.
Also, as noted, the '88 pipes are different than '84-'87 pipes where they route around the front suspension.
And because the coolant connections are all at the pulley end of the engine, there's a crossover pipe bolted to the engine connected to the left coolant pipe by a hose.
