  Question about shifter select cable routing
Question about shifter select cable routing by Benn2002
Started on: 04-12-2021 10:37 PM
Replies: 4 (106 views)
Last post by: Patrick on 04-13-2021 02:29 AM
Benn2002
Report this Post04-12-2021 10:37 PM Click Here to See the Profile for Benn2002Send a Private Message to Benn2002Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, quick question here, I just ordered rodney's select cable the other day and I installed it and it's still quite hard to push to go over to 1&2 and 5&R. I am wondering (since there is a pretty tight bend where it goes over the crossover pipe) is it supposed to go BELOW the crossover pipe? Because I put it over it, the heat insulation on the cable is being squeezed between the pipe and the cable. Thank you!!
Total ratings: 463
Report this Post04-12-2021 10:49 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's a diagram that's been posted here many times over the years that shows the correct routing of the cables. If you can't find it using the Search function, perhaps someone will post it here again.
Benn2002
Report this Post04-13-2021 12:05 AM Click Here to See the Profile for Benn2002Send a Private Message to Benn2002Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am aware of that picture, it doesn't have the corssoverpipe even labeled or on that diagram.
fierosound
Total ratings: 286
Report this Post04-13-2021 01:55 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Benn2002:
I am aware of that picture, it doesn't have the crossoverpipe even labeled or on that diagram.
Shift cable goes over the crossover pipe, not select cable.
Select cable goes between firewall and heat shield and down to side of exhaust downpipe as shown.
[This message has been edited by fierosound (edited 04-13-2021).]
Total ratings: 463
Report this Post04-13-2021 02:29 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That diagram looks very familiar.
