  17”18” Rim options for a mera body kit.
17”18” Rim options for a mera body kit. by GVV_ACE
Started on: 04-07-2021 05:39 PM
Replies: 10 (302 views)
Last post by: hnthomps on 04-16-2021 10:36 AM
GVV_ACE
Report this Post04-07-2021 05:39 PM Click Here to See the Profile for GVV_ACESend a Private Message to GVV_ACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey everyone. I need some help figuring out what wheels to buy. I have a 85 with a Mera/style Ferrari 308 panels with no coil overs, all stock. Currently have 15” 308 type rims. I love these rims but can’t find new rubber for them. So I decided to go with a bigger/modern size for more tire options.
Does anyone have 17” or 18” rims on their Mera?
What width and offset did you use?
Back space?
I want to find something that will look flush with the fender.
GVV_ACE
Report this Post04-07-2021 05:41 PM Click Here to See the Profile for GVV_ACESend a Private Message to GVV_ACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is a pic of my current wheels.
Total ratings: 236
Report this Post04-08-2021 08:08 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
C5 Corvette 18x9.5 rear wheels with 285/30 tires will fit under stock bodywork with 1" thick bolt pattern adapters. They'll be pretty close to the struts... not sure about clearance to the stock spring perch.
hnthomps
Total ratings: 50
Report this Post04-09-2021 09:49 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Back space?
What size tires are you looking for?
Nelson
GVV_ACE
Report this Post04-09-2021 12:48 PM Click Here to See the Profile for GVV_ACESend a Private Message to GVV_ACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay thanks, if I have to go to coil overs to make something work I will.
GVV_ACE
Report this Post04-09-2021 09:01 PM Click Here to See the Profile for GVV_ACESend a Private Message to GVV_ACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
GVV_ACE
Member since Oct 2018
Nelson
If you mean what size was I looking for on the old rims,
I had 245/50/15 rear and 255/50/15 front.
I can find front rubber, nothing for rear.
I bought 245/60/15 and 255/60/15 and had front rub issues and just looked too big.
RCR
Total ratings: 102
Report this Post04-09-2021 10:35 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
If I did my homework correctly, I will be running 18x8.5 x 35mm for the front, and 18x10 x 25mm for the back.
I'm looking at a 26" tire height, so I will target 225/45/18 for front and 255/45/18 for the rear.
Bob
My Build
Total ratings: 236
Report this Post04-12-2021 06:25 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bob
255 is a narrow tire for a 10" wheel... you should be able to fit a 285/40 on that wheel... not sure about your bodywork.
You should be able to run offset up to 30 on an 18x10 rear and still have acceptable strut clearance.
hnthomps
Total ratings: 50
Report this Post04-13-2021 10:16 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stock Mera tires were 245 x 50 x 15 on the front and 265 x 50 x 15 on the back. Where did you manage to find the 245 x 50 x 15 tires because I have been looking for them for years? You can run the 265 tires on all four corners but may have a slight rub in the front when making sharp turns at slow speeds. The 265 tires are currently available in a couple of brands. I know that Hankok is one of them and have used several of them on my tires. Cooper did make a 265 tire but I do not believe that they are currently available in the 265 x 50 x 15 size.
Nelson
GVV_ACE
Report this Post04-15-2021 08:54 PM Click Here to See the Profile for GVV_ACESend a Private Message to GVV_ACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nelson
Nelson the 245/50/15 were on the car when I got it 2 years ago and it sat in the guys garage for years so I’m sure he got them in the 80s or 90s. I can’t find new ones anywhere. I hate to have to go to a bigger rim when the car came with great looking 15s. I’m getting a complex asking around for that size of tire , they all laugh at me on the phone and say “good luck finding anything in a 15!” Lol
Thanks for the info.
hnthomps
Total ratings: 50
Report this Post04-16-2021 10:36 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently purchased 265 x 50 x 15 tires for a couple of my Meras. Hankook and at least one other manufacturer still make them. Galaxy R1 (by Vitour) also advertises a tire in 265 x 50 x 15. I also see an ad for Cooper P265/50R15 COBRA RADIAL G/T tires at this time.
My specific Hankook tires are rated to about 120 mph so that is not a real factor for me.
Nelson
