  Pinched Coolant Tube Symptoms
Pinched Coolant Tube Symptoms by cmd88
Started on: 04-07-2021 11:19 AM
Replies: 1 (123 views)
Last post by: theogre on 04-07-2021 11:49 AM
cmd88
Report this Post04-07-2021 11:19 AM Click Here to See the Profile for cmd88Send a Private Message to cmd88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Coolant tube has a dent from careless jack point. . Car is still running at normal temp. Should I be concerned? What are symptoms of restricted flow?
cmd88
Report this Post04-07-2021 11:49 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Restricted flow for any reason is same, engine runs hot or worse.
Temp Gauge on dash often lies, scan ECM for temp, check T-stat tube w/ IR or other temp meter, etc, before doing any work.
If coolant pipes under car is bent even a little you have Crushed Pipe.
Remove/loosen support hardware to look at rear of pipes at minimum.
Many Fiero have broken rocker panels and body damage too because morons jack the car wrong.
Beyond that, most T-stant can make big temp swings more so at idle or low speeds.
Replace T-stant w/ Stant superstant. Even tho may look same as others, is not and stops wide temp swings.
See my Cave, Thermostat and most of rest of section.
